another b16 dyno
Old Sep 26, 2004 | 10:34 PM
SioneSi's Avatar
Default another b16 dyno
Just got back from tuning with a hondata s100 and here are the results.
12/06/03 dyno- 186.1hp & 117.2ft/lb. this is a p28 ecu with ericksracing chip that he tuned on the dyno for my set-up.
09/26/04 dyno- 188.8hp & 127.3ft/lb. this is still the same set-up but ditched the chip the erick made and replaced it with a hondata s100.
here's the set-up
skunk2 stg1
competition port and polish and welded chambers/milled 0.023
hondata p28 ecu with S100
jdm dc header
iceman intake
2.5 catalytic
2.5 catback
itr t-body & manifold
Spoon flywheel
stock block & stock head gasket
compression is @ 10.7
Old Sep 26, 2004 | 11:19 PM
Tad's Avatar
Tad
man that motors all about the vtec aint it
Old Sep 26, 2004 | 11:23 PM
EJBomexCoupe's Avatar
nice numbers
Old Sep 26, 2004 | 11:24 PM
Gump's Avatar
Default Re: another b16 dyno (SioneSi)
Nice! What valvetrain are you running?
Old Sep 26, 2004 | 11:29 PM
G U E C O's Avatar
thats alot of hp for a b16
Old Sep 26, 2004 | 11:32 PM
SioneSi's Avatar
Default Re: another b16 dyno (Gump)
itr outers and alaniz inners on both in/ex. yep all about the vtec
thanks
Old Sep 26, 2004 | 11:43 PM
anothersickhatch's Avatar
where did you get your car tuned? do you remember what the temperature was?
i only ask cuz i should get those same numbers. hoping for a little more...
Old Sep 27, 2004 | 01:07 AM
Waachback's Avatar
very nice numbers....what were your cam timings set to on those skunk2's?
Old Sep 27, 2004 | 01:58 AM
@ries's Avatar
Dang! That's some nice tq. gains.
Old Sep 27, 2004 | 03:08 AM
RobbieG35's Avatar
12 Years Strong
Default Re: another b16 dyno (@ries)
Just like my B16, nothing happens until VTEC
Numbers look good man
Old Sep 27, 2004 | 06:19 AM
BACKintheDA's Avatar
Default Re: another b16 dyno (HybridHatch88)
very nice numbers man, I hope to reach 180whp
Old Sep 27, 2004 | 07:08 AM
SioneSi's Avatar
Default Re: (Waachback)
the stg1 settings are at 2 deg advance both in & ex and the temp that day was 74 in the southbay.
Yeah , the torque gain that I got was a surprize to me and even the tuner but more on me though tuner said that I was runnning extremely rich and all it took is abit of fine tuning on the low end side. Car feels so much better and responsive compared to before.
The dyno used is a dynapak.
dynoed @ Church Automotive Testing
Old Sep 27, 2004 | 08:46 AM
thenick's Avatar
how do dynopacks read in relation to dynojets?
nice #'s by the way
Old Sep 27, 2004 | 09:13 AM
smart monkey's Avatar
nice #'s that ported head and tuning helped a lot
Old Sep 27, 2004 | 09:31 AM
grenthang's Avatar
Default Re: another b16 dyno (smart monkey)
Thats some really nice numbers.
Old Sep 27, 2004 | 11:11 AM
SpdFrk's Avatar
Those are awesome numbers for your setup.
Old Sep 27, 2004 | 12:22 PM
Tad's Avatar
Tad
that chart says that it is flywheel hp??
Old Sep 27, 2004 | 12:57 PM
99skunkedSi's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">that chart says that it is flywheel hp??</TD></TR></TABLE>
yeah i saw that 2 thats probably why they seem so high. still those are some good numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">how do dynopacks read in relation to dynojets?</TD></TR></TABLE>
i think they read flywheel hp instead of whp.
Old Sep 27, 2004 | 02:14 PM
92RED Hatch's Avatar
Default Re: (99skunkedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99skunkedSi &raquo;</TD></TR><TR><TD CLASS="quote">
i think they read flywheel hp instead of whp.</TD></TR></TABLE>
That would explain quite a bit....prob puting down 160-165 to the wheels..
Old Sep 27, 2004 | 03:13 PM
BluSiBoy's Avatar
Nice #s man, I guess the best thing you did had to do with the ECU your using
Old Sep 27, 2004 | 03:36 PM
AllMotoRex's Avatar
Default Re: another b16 dyno (BluSiBoy)
either way . nice numbers!!
Old Sep 27, 2004 | 05:01 PM
14bcoupe's Avatar
Default Re: another b16 dyno (AllMotoRex)
its not flywheel , im looking at mines and at my friends dyno sheets and they both say flywheel on the top, but those numbers are too high dynapacks usually registers lower whp than the dynojets from my experience, so on a dynojet your numbers would have been higher, which cant be explain, cause you got stage 1 cams with only 10:7 compression, and simple mods,so your torque and hp numbers look almost impossible on a b16 stock bore/stroke with those mods.
Old Sep 27, 2004 | 05:26 PM
mrtrex's Avatar
Default Re: another b16 dyno (14bcoupe)
dynopack dynos measure at the hubs because you take off you wheels. The less mass that you engine uses the more power you will have. So taking off the wheels will show more power. They are still good numbers.
Old Sep 27, 2004 | 06:23 PM
SioneSi's Avatar
Default Re: (92RED Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92RED Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
That would explain quite a bit....prob puting down 160-165 to the wheels..</TD></TR></TABLE>
close dynojet I dynoed @ 179.5 whp and 120.4 ft/lbs
Dynapacks show higher results but basically I choose this dyno because of its tunability features that dynojets don't have. The best mod that I did on my car is definitley the hondata s100 and church automotive testing.
Numbers are high I was surprised myslef but the tuner said welding the chambers on the head of course increases comp but also improves quench area of the combustion chambers, thus giving better results. But there are more factors to consider .
Old Sep 27, 2004 | 07:37 PM
nyce1's Avatar
Those are definitely some impressive numbers for that type of setup. It looks as though the ECU made the difference.
