Headgasket question
Old Sep 26, 2004 | 10:10 PM
EGkid's Avatar
Default Headgasket question
Okay here goes, i wanted to build an lsvtec with pr3 pistons, ls rods, etc. I planned on using a GSR head with some toda spec b camshafts and i wanted to bump up my compression ratio with a 1 layer headgasket so i could yield better hp numbers with my toda cams.
Is this a big no no? Am i better off with an OEM 3 layer or can i safely run this headgasket? I was told i would be about 45,000's off from piston to valve and that doesn't really give me any room for cam tuning ability. What do you guys think
Old Sep 26, 2004 | 10:35 PM
JDMlyfestyle's Avatar
check out cometic headgaskets. they have any kind of gasket that u want.
Old Sep 27, 2004 | 04:33 AM
EGkid's Avatar
Default Re: (JDMlyfestyle)
but would i be okay running a one layer?
Old Sep 27, 2004 | 08:55 AM
EGkid's Avatar
Default Re: (EGkid)
another question...all you guys running toda b's...how many degrees do you have the cams set at?
Old Sep 27, 2004 | 03:16 PM
EGkid's Avatar
Default Re: (EGkid)
bump!
EGkid
Sep 28, 2004 07:24 PM
jaydmcrx
Jan 27, 2004 12:56 PM
b18jdmteg
Nov 7, 2003 10:06 AM
Beave0101
Jan 1, 2003 06:35 PM
slowcivic
Aug 9, 2001 09:15 AM
