Y8 swap in EF, help a brotha out, obd1 swap questions
Old Sep 26, 2004 | 09:39 PM
hatchback_al's Avatar
Default Y8 swap in EF, help a brotha out, obd1 swap questions
Ive had a y8 swap in my car for some time now, but i trashed the block. So I am replacing the block with another y8 block and converting to obd1 now ( i was running obd0 with vafc before). The question is, how well will the obd1 z6 distributor mount on the y8 head? Can I use a d15 obd1 distributor for the obd1 swap? Will there be any issues I run in to using the boomslang/blown hatch obd1 harness and the obd2 motor? thanks.
-Alex
Old Sep 26, 2004 | 11:26 PM
Default Re: Y8 swap in EF, help a brotha out, obd1 swap questions (hatchback_al)
bump
Old Sep 26, 2004 | 11:47 PM
Jaker's Avatar
You should have no issues with the harness. The Z6 distributor will not bolt to the Y8 head. The D15 one will work. However, the Y8 distributor will work just fine with OBD1.
Old Sep 26, 2004 | 11:53 PM
Default Re: Y8 swap in EF, help a brotha out, obd1 swap questions (Jaker)
ok thats good to know, thanks, anyone wanna share more?
Old Sep 27, 2004 | 07:03 AM
4drEF's Avatar
Keyboard Humorist
I'm running an OBD-1 D15 distrbutor on a Y8 head.
It bolts up fine and works fine with the P28 OBD-1 ECU.
Old Sep 27, 2004 | 10:23 AM
Default Re: Y8 swap in EF, help a brotha out, obd1 swap questions (4drEF)
good to know thanks
Old Sep 27, 2004 | 10:26 AM
Cornwhiskey's Avatar
sounds right to me
Old Sep 27, 2004 | 11:31 AM
Default Re: Y8 swap in EF, help a brotha out, obd1 swap questions (sparvar)
Ok, Im thinking of converting to obd1 by myself. The cost of a conversion harness is enough to buy head studs and a timing belt, both of which I need. Does anyone know where I can find a really good writeup on doing it yourself. I used the search and found a few things but would look to see if you guys find any better stuff Thanks.
-Alex
inh
Jul 30, 2006 06:38 PM
crx2ner
Jun 30, 2005 07:30 PM
vegaskurt
May 14, 2005 10:17 PM
builthatch
Jan 25, 2004 09:49 PM
SOHC_MShue
Oct 29, 2003 07:57 PM
