Anyone have the Rsx Type S Gauge cluster Pinouts?
Old Sep 26, 2004 | 07:19 PM
KustomCrx's Avatar
Default Anyone have the Rsx Type S Gauge cluster Pinouts?
Im looking for the pinouts for the gauge cluster for rsx type s. if you have a site or something to help me, please let me know.
Old Sep 26, 2004 | 07:33 PM
Ocelaris's Avatar
Default Re: Anyone have the Rsx Type S Gauge cluster Pinouts? (KustomCrx)
There's a guy on ephatch Bemunger (probably name wrong) who has swapped a RSX gauge cluster into an EP3... so he knows all the pinouts and everything... just search for rsx cluster or gauge on ephatch...
Old Sep 27, 2004 | 04:43 PM
Modern91Hatch's Avatar
I'm working on the same project too. I've downloaded the RSX Service Manual at:
http://johnscustompcs.com/03rsx-s/HELMS_RSX.pdf
I'm working on Bookmarking all the Sections and sub-sections. I'll post soon. The some of the cluster info begins around page: 1211
Pin out Info:
-B is the smaller connector (on the left looking at the back)
-Pinout for B goes 1(top Left) - 9 (Top right) | 10 (Bottom Left) - 18 (Bottom right)
Pin for connector A is the same + 4)
Most LEDs should be pulled to ground to light, Some, however, must have +12v to make them light.
Here's what I got so far:
CONNECTOR A:
A3 LED - Security Indicator
A4 +12v for Immobilizer
A5 LED- High Beam
A6 +12v for High Beam LED
A7 LED - Left turnsignal (must apply +12v)
A8 LED - Cruise Control
A10 LED - Immobilizer
A13 Dash Lights Output (I believe the4 CPU control brightness)
A14 ABS Control Unit Inuput
A15 LED - SRS Unit (must apply +12v)
A21 LED - Oil Pressure
A22 LED - Check Engine Light
CONNECTOR B:
B6 +12v (On all the time)
B7 +12v (Ingition switch-on)
B8 LED:Side Airbag Off
B9 LED:Turn Signal (must apply +12v)
B13 Connects to Multiplex-which controls many inputs
B14 Tachometer
B15 VSS(Vehicle Speed Sensor)
B16 Fuel Gauge
B17 GROUND 1
B18 GROUND 2
This is all I have so far. I believe you also need the Multiplex Unit that connects to Pin B13. The think Multiplex has several inputs:
-Coolant Temp
-Seat Belt Warning LED
-Break LED
-Door Open Indicator
-Charging System LED
I don't know if you can control these with other Pins on the cluster. I'm wokring on it now. I'm putting this RSX cluster in my 91 Civic Si. I think it will fit, but it will be a tight one. If anyone has more infomation on doing this cluster install, please let us know! Also if anyone has info on Putting a VSS on a Cable Tranny. I think... it's a direct fit.
Current Setup:
91 Civic Si
JDM DOHC ZC
Intake + Header
Stock Exhaust
Soon:
JDM B16A2
OBD0-OBD1 Setup
RSX Cluster
Old Mar 6, 2005 | 08:27 PM
EK9Greg's Avatar
bump
Old Feb 4, 2017 | 08:12 PM
Alfredo Medina's Avatar
lemongreenhatch
Texas -OK -LA (Sales)
Jun 13, 2010 10:04 PM
nicko360
Northwest (Sales)
Jul 18, 2007 07:07 PM
KOREAN
Mar 16, 2006 01:34 PM
mrsurfermike2001
Apr 10, 2003 09:24 AM
