Power Windows AND Sunroof NOT Working!!! PLEASE HELP
Okay, So my friend bought a gsr and it came with this like cell phone/microphone/antenna hook up. So to take it out we had to cut some wires. Then there was a spark, my dumbass forgot to disconnect the negative. Weird thing is, one of the wires was connected in with the 20A door locks fuse.. the other wires were the mic/antenna wires and then the postive and negative wires hooked into the battery,
So we start the car and the windows and sunroof dont work.
What could this be? We checked all the fuses, they look fine. What about the relay? Should we replace fuses anyway...
Please Help! His windows are stuck down!
hmm. did you check the fuses under the hood also? fuses should save you from ******* everything else up when you do something retarded like that, lol.
the best bet i would tell you is to bust out a light tester and start testing for power in the control panel and stuff like that. if there no power its either the fuse or the control.
russell707
Apr 26, 2010 04:33 AM
willymac22
Mar 9, 2004 09:38 AM
MestizoRacer310
Nov 25, 2003 10:57 PM
