car won't start
Old Sep 26, 2004 | 03:03 PM
vxnine's Avatar
Default car won't start
my car broke down on my way home today. the way it stopped was the car started slowing down and when i pushed the gas pedal it wouldnt go anymore, so i pulled over and my car wouldn't start anymore. it cranks up but it wont actually start. im guessing it has to do with something fuel related obviously? but what?
Old Sep 26, 2004 | 03:14 PM
SOHC4life 96's Avatar
Default Re: car won't start (frankcivic)
My mom had a similar problem happen to her on her way home from Laughlin(sp). Turned out it was her fuel pump. She was driving, then it just lost all power. Have you tried starting since this happend?
Old Sep 26, 2004 | 03:30 PM
vxnine's Avatar
Default Re: car won't start (DOHC4life)
yeah we had it towed back to the house so its in my front yard. it sounds like its about to start but it doesnt
Old Sep 26, 2004 | 03:44 PM
How long has it been since this happend?
Old Sep 26, 2004 | 03:50 PM
vxnine's Avatar
it happend today... maybe 4 to 5 hours ago? not long
Old Sep 26, 2004 | 03:54 PM
Yeah, I think you should have a shop look at your fuel pump. Unless you know its not. Her car would start up and work for a while then it would die. So Im not positive if this is the case. One thing that surprised me was that the shop drove her car around town (Bakersfield) for almost 2 hours until the car died. I found that very interesting.
Old Sep 26, 2004 | 03:55 PM
deSigi's Avatar
Turn your key to get your accessories to work, but don't crank the engine. When the key is turned, you should hear the fuel pump surge from the rear of the car. If you don't you might begin by finding out if the fuel is functioning.
Just a suggestion. Good luck with the diagnostic.
Old Sep 26, 2004 | 04:01 PM
vxnine's Avatar
Default Re: (deSigi)
okay i did the thing, yeah i heard fuel come from the back of the car.. so its not the fuel pump eh? ya guys know what the problem might possibly be?
Old Sep 26, 2004 | 04:02 PM
Default Re: (frankcivic)
Could be a clogged fuel line or filter.
Old Sep 26, 2004 | 04:03 PM
Agent Daimon's Avatar
check for spark.
no spark = replace the coil in the distributor
Old Sep 26, 2004 | 04:16 PM
vxnine's Avatar
Default Re: (Agent Daimon)
spark would be visible if i just popped the hood open while someone tries to start the car right?
Old Sep 26, 2004 | 04:30 PM
pull out a plug wire
Old Sep 26, 2004 | 05:11 PM
civicmon's Avatar
I'm thinkin distributor.. fairly common on honda's for them to go out but with how they work it's not suprising.
Old Sep 26, 2004 | 05:17 PM
vxnine's Avatar
Default Re: (civicmon)
i pulled the wires that go to the distributor and my brother tried to start the car and there was no spark in them, so is it the wires or the spark plugs??
thisboyjulio
Sep 20, 2009 12:06 PM
devin_hoang
11
Dec 31, 2008 06:01 PM
Accord15
Jun 25, 2003 09:54 AM
