AC Compressor kicks on and off randomly
Old Sep 26, 2004 | 12:35 PM
jlamaster's Avatar
Default AC Compressor kicks on and off randomly
My AC compressor will just cycle on and off randomly while driving. What is causing this?
Old Sep 26, 2004 | 12:43 PM
Shaun's Avatar
Default Re: AC Compressor kicks on and off randomly (jlamaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlamaster &raquo;</TD></TR><TR><TD CLASS="quote">My AC compressor will just cycle on and off randomly while driving. What is causing this?</TD></TR></TABLE>
im having the same prolem , except for my a/c I have to keep it on the highest level so the compressor can stay one, me and my freind beilive its caused by the gray can which is a filter, that could be clogged, I never got around to changing it myself to see if it was the problem. also maybe you could be runing low on freon?or compressor is going bad
Old Sep 27, 2004 | 12:08 PM
veggiemaster's Avatar
hey guys, thats what an ac compressor does. Its called cycling. What it does is an electromagnetic clutch kicks in which causes the compressor to kick in, also, thats when your car looses power, they cycle so that your car isnt always being drained, and so that there isnt an excessive loss of coolant juice. so dont worry, thats what they are suppose to do.
Old Sep 27, 2004 | 12:17 PM
ABK's Avatar
ABK
Default Re: AC Compressor kicks on and off randomly (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, thats what an ac compressor does. Its called cycling. What it does is an electromagnetic clutch kicks in which causes the compressor to kick in, also, thats when your car looses power, they cycle so that your car isnt always being drained, and so that there isnt an excessive loss of coolant juice. so dont worry, thats what they are suppose to do.</TD></TR></TABLE>
Old Oct 1, 2004 | 05:40 PM
jlamaster's Avatar
Default Re: AC Compressor kicks on and off randomly (ABK)
Yeah i am aware of "normal" cycling however mine will kick "on" for about 30 seconds then kick "off" for about 10 min.
Old Oct 1, 2004 | 05:54 PM
ABK's Avatar
ABK
pssibly a leak or needs to be recharged.
Old Oct 1, 2004 | 06:49 PM
Arsenal's Avatar
LOL I just spent about $500 at Honda and other places trying to fix the exact same problem.
Here is the bad news, it is the AC thermostat which is in the evaporator under the dash.
The freon needs to be drained before you can take it out. I believe the part was $30 form Honda, then about $135 for them to do it. Not too bad.
Good luck.
Old Oct 1, 2004 | 07:01 PM
Shaun's Avatar
Default Re: AC Compressor kicks on and off randomly (Arsenal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">LOL I just spent about $500 at Honda and other places trying to fix the exact same problem.
Good luck.</TD></TR></TABLE>
did the have the replace the gray round canister? is that what you mean?
Old Oct 1, 2004 | 07:12 PM
Arsenal's Avatar
Default Re: AC Compressor kicks on and off randomly (Shaun)
Nah, its a small connector, but located in a big box under passenger side of dash.
Davidss
Jul 16, 2009 05:51 AM
Civic Racer X 7
Aug 8, 2007 05:15 PM
tub_sephiroth
Jun 27, 2005 11:13 AM
jabroni95gsr
Nov 19, 2001 11:38 AM
