Power steering issue...
Old Sep 26, 2004 | 10:50 AM
ProLineDesigns's Avatar
Default Power steering issue...
I have an 98 Accord Coupe EX J30 98K that needs a new power steering pump I believe. Before I go delving into the motor I thought I'd post a thread for any advice.
Syptom:
Just noticed (like today) a whine by the belts, it increases and decreases in volume as I turn the wheel. The noise is a hydraullic noise that sounds like PS but I wanted to make sure.
I consider myself an 8-9 on a scale of 1-10 regarding technical ability. Looking at the pump, it doesn't look too hard of a job. However I want to make sure I do it right since I have never replaced a PS pump on a Honda. Please advise...
Old Sep 26, 2004 | 11:38 AM
sj993's Avatar
Default Re: Power steering issue... (ProLineDesigns)
Yeah I had the same noise and it turned out to be the power steering pump. Most likely that's what it is.
Old Sep 26, 2004 | 11:41 AM
huyvu90's Avatar
check the tightness of the belt first. Too tight can make it whine.
Old Sep 26, 2004 | 03:55 PM
Default Re: (huyvu90)
The more I listen to the noise, the more it sounds like the alternator. It sounds like the bearing is shot in it. How long can I drive on it before encountering amperage loss? It still turns over fine. Anyone have any tips for changing it out? I am going to take it to the dealer so they can diagnose it in the morning just to make sure. Thanks...
Old Sep 26, 2004 | 04:17 PM
Default Re: (ProLineDesigns)
P.S. Do you have to replace the alternator of the same kind? The one in there now is Delphi. Can I use a Delco? Thanks...
integra15
May 27, 2011 04:27 PM
tx95excoupe
Sep 24, 2007 10:19 AM
CRXTAZC
Dec 11, 2006 12:41 PM
Honda97
Mar 12, 2005 08:20 AM
PorscheGT2
Oct 5, 2001 07:13 PM
