gauges dont work
Old Sep 26, 2004 | 05:38 AM
Ej1_coupe's Avatar
Default gauges dont work
I had a recent thread that stated that some of my lights didn't work, like dash, rear lights, and license plate lights. Well, I discovered it was a blown fuse. Well after replacing the fuse I turn my car on and start to drive, then notice NONE of my gauges are working. Speedometer,rmp's,gas. Then as i try to put on my turn signal, nothing. No clicking indicating the turn signal is on, or a green arrow on the dash, and my turn signals don't work. Hazards do work though.
So I returned home and pulled every fuse out, none of them are blown. Then I just drive the car as is cause I needed to go somewhere, using my fields vtec controller's km/h function to tell how fast I am going. Then on my way I blow the dash lights, license plate light etc.. fuse again.
Anyone have any ideas of what I can try to do to figure out the gauges problem? Thanks
Old Sep 26, 2004 | 06:00 AM
Boostage's Avatar
Default Re: gauges dont work (Ej1_coupe)
same thing happened to me, turns out when i checked all my fuses I put the dash one in the wrong spot. it was on spot over., but u obviously have a grounds problem also.
Old Sep 26, 2004 | 06:39 AM
EJ8 D15Y8's Avatar
My guages havent worked in months !!!!
It is ridiculous, I blew my last motor because it overheated.
PM me if you find anything out.
BTW do your headlights/tails/interior lights ever surge ? If they do, its your under dash fise "alterantor sp". Only problem for me is it keeps blowing.
accorkie
Sep 16, 2005 12:23 PM
KYLE.ECKERT
Aug 29, 2005 03:13 PM
SIanara
Aug 10, 2005 08:28 PM
wu tang
Jun 8, 2004 04:26 PM
