itr rear lower tie bar on gsr
Old Sep 26, 2004 | 04:07 AM
-faded-'s Avatar
Default itr rear lower tie bar on gsr
i have a friend who is selling a oem jdm itr rear lower tie bar, would this be a worthwhile upgrade to my gsr? is it a direct bolt on? thanks for any help
Old Sep 26, 2004 | 04:45 AM
gsrboi80's Avatar
Default Re: itr rear lower tie bar on gsr (hybridlsR)
tie bar or sway bar?
If its the sway bar yea go for it best suspension upgrade you can do youll need an installation kit just search covered many times. Peace
Old Sep 26, 2004 | 05:32 AM
-faded-'s Avatar
Default Re: itr rear lower tie bar on gsr (gsrboi80)
its the tie bar.
yeah i know about the sway bar, i will be purchasing that very soon also
Old Sep 26, 2004 | 05:58 AM
mls's Avatar
mls
This is the one you mean? (abeit a picture of an EK):
If it is, then it won't bolt-on to your GS-R, unless you weld the Type R suspension arm pick-up sheet metal "sub-frame" to your car...
Old Sep 26, 2004 | 06:01 AM
uLTrAvTEc757's Avatar
Default Re: itr rear lower tie bar on gsr (mls)
i wanted to do the same thing to my gsr but i knew it wouldnt fit....i wanna get a cusco 1 peice tie bar, you might wanna check into one also....
Old Sep 26, 2004 | 06:49 AM
Try2Live4God's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mls &raquo;</TD></TR><TR><TD CLASS="quote">
If it is, then it won't bolt-on to your GS-R, unless you weld the Type R suspension arm pick-up sheet metal "sub-frame" to your car...</TD></TR></TABLE>
This is correct. It won't fit on the GS-R. Try looking into DC Sports lower tie bar as well. Be aware that a lot of lower tie bars conflict with the ABS lines!
Old Sep 26, 2004 | 06:56 AM
mls's Avatar
mls
You could also look into Z.Speed & Skunk2 (they both appear identical to me).
Old Sep 26, 2004 | 08:55 AM
opiumdaze's Avatar
no it wont fit because ITR's have a designated place to attach it and the GSR doesnt..dont buy it, i had to learn the hard way
Old Sep 27, 2004 | 04:26 AM
-faded-'s Avatar
Default Re: (opiumdaze)
thanks for the info guys. what cars do they fit on?
Old Sep 27, 2004 | 05:56 AM
opiumdaze's Avatar
see the two things i circled? RS LS GS GSR doesnt have it so youd have to weld a bracket on or go aftermarket
Old Sep 27, 2004 | 06:12 AM
-faded-'s Avatar
thanks for the info man. let me know whats up with the emblems
DC2 Mang
Suspension & Brakes
12
May 12, 2020 09:12 AM
Ek-Xang
Feb 4, 2010 12:30 AM
SamuraiJack
Oct 15, 2002 11:39 PM
B18C1_EK
Feb 28, 2002 12:01 PM
ZUL8R
Aug 24, 2001 10:05 AM
