~~~ DOOR WON'T OPEN ~~~
Old Sep 25, 2004 | 11:30 PM
Tutin77's Avatar
Default ~~~ DOOR WON'T OPEN ~~~
My passenger door will not open... not with the key, not with the automatic door opener from either side, and it won't open by force of hand!!
Anyone experience something like this before? what can I do?
Any advice is appreciated.
Modified by Tutin77 at 1:02 AM 9/26/2004
Old Sep 26, 2004 | 03:34 AM
ryanstev's Avatar
The door lock connecting rods have slipped out, possibly due to someone trying to jimmy the door open.
You'll need to open the door and take the inside cover off so you can put them back in, since the problem is you can't open the door in the first place, I'm not sure how you can do this.
The same thing happenned to my parent's Galant after I locked the keys inside and had someone try to break in, the garage managed to fix it.
Old Sep 26, 2004 | 08:53 AM
ViZ's Avatar
ViZ
im not sure you can get the door panel off with the door closed.. you would have to remove the pass. seat to give yourself enough room..
you can take the handle and switches off and see if you can manuver or pull the rods from there to unlock it
Old Sep 26, 2004 | 02:22 PM
britishlude's Avatar
Default Re: ~~~ DOOR WON'T OPEN ~~~ (Tutin77)
Take it into a locksmith shop who deal with cars they will have the slim jims that go down between the door glass and seal, that will be able to lift your locks and open the door.
Old Sep 26, 2004 | 02:37 PM
sniffthese's Avatar
Default Re: ~~~ DOOR WON'T OPEN ~~~ (britishlude)
Either kick that **** open or go to your closest shop and tell them to open that ****.
headdles
Dec 9, 2014 12:20 AM
NACvicSi
12
Jul 18, 2009 06:00 PM
Tarlacon
Dec 14, 2008 03:54 AM
callmetree19
Jun 29, 2008 02:17 PM
4drEF
Sep 7, 2004 01:32 PM
