Help with door panel
My girlfriend has a EP3 and her inside door handle stopped working. It happened right after the windows were tinted, so I am hoping the rod just popped out. What I need to know is how to get the door panel off, is there a trick to it?
on hondas the door panel is easy to pop off. but just make sure you take out all the necessary screws. there should be about 4. I've takin my rsx door panel off before. it just pops off.
well my problem is where the door handle is. I got every thing disconncected up to there. Does the handle by the door handle come off? In my prelude I just hold the door handle open and pop the cover off, but it doesn't seem that simple with this.
Edit: fixed the door, the cable popped out of the door handle. Since I had enough clearence I just stuck my hand in thier and pushed it back in.
Modified by OEM_ASSASSIN at 7:42 PM 9/25/2004
Theres probally a couple of screws ur missing i had that problem with my rsx the was a screw hidden behind the door handle but once i got that screw and the other hidden ones out, the panel came right off
suhteevin
Jan 6, 2009 09:04 PM
Frost7177
Oct 27, 2008 01:31 PM
Mike banX
Sep 29, 2003 11:42 AM
