Installing CD Player 99 civic
Old Sep 25, 2004 | 05:17 PM
EnriqueDovis's Avatar
Default Installing CD Player 99 civic
Hi guys this is my first post. i recently bought a 99 civic with a stock cd player included. The cd player does not like to read burned cds and i want to install a new cd player in there. The thing is the cd player configuration is weird. there is a radio control on top of the actual cd player unit that just has an eject button. the radio on top has the controls to the cd player on the bottom and i was wondering how a person goes about installing a new cd player in there if there is a radio and a cd player in two different spots. thank you so much for your information!!!!
Old Sep 25, 2004 | 05:30 PM
john666's Avatar
Default Re: Installing CD Player 99 civic (EnriqueDovis)
probably take both out and go to a honda dealer/junk yard and buy the pocket to take up the empty space.
Old Sep 25, 2004 | 06:03 PM
JDMFreak's Avatar
Default Re: Installing CD Player 99 civic (john666)
you must have a radio unit with a slave cd player unit...i have a 99 factory cd player and it reads burn cd fine...the only think i can think of is how fast did you burn the cd??? i burnt my at 1x took a while but it works and it last a little bit longer in my opinion i have tried this on double units and single and it works....
Old Sep 25, 2004 | 07:01 PM
ill try burning at slow speeds what program do u use to burn? i use nero
Old Sep 26, 2004 | 08:05 AM
EK JayJimenez's Avatar
i recently got my stock radio replaced with a kenwood deck in my 00 hatch - what you could do is got to curcuit city and buy the 00 civic installation kit and get a new wire harness. then take off ur center console and unplug and the wires goin to the fan and all of that stuff. plug in ur new wiring harness and pull out the old 1. use the tray they give you to place ur deck. screw everythin in andplug everythin in and put back on ur center console . OR u can do it the easy way and have curcity city do it. my friend works in the installition department and he did mine for free.
Old Sep 26, 2004 | 08:36 AM
so when they install it at circuit city, then they will take out both cd player and radio??
Old Sep 26, 2004 | 09:34 AM
JDMFreak's Avatar
Default Re: (EnriqueDovis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnriqueDovis &raquo;</TD></TR><TR><TD CLASS="quote">ill try burning at slow speeds what program do u use to burn? i use nero</TD></TR></TABLE>
i used easy creator, try burning it slow..and tell me what happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnriqueDovis &raquo;</TD></TR><TR><TD CLASS="quote">so when they install it at circuit city, then they will take out both cd player and radio??</TD></TR></TABLE>
if you replace it with a after market stereo then yes,
Old Sep 26, 2004 | 12:37 PM
your only gonna have 1 in your car.. Whhat?? do u want both??for what..when just the cd deck does both.. ur not gonna have both in ur car...its only 1
Old Sep 26, 2004 | 01:03 PM
thanks for the information guys i figured out what it would look like if they took out the cd player and replaced it with a tray but thats prolly what ill do thanks a lot for the info!!
Old Sep 26, 2004 | 02:09 PM
vtekstorm's Avatar
did u try burning it as a aduio cd or a mp3 cd? i use nero also. i made the mistake of burning my cd as a mp3 and it didnt work in my car. so i tried audio cd and works like a charm
Old Sep 26, 2004 | 02:14 PM
Frozen E's Avatar
H-T White Ops
Get yourself a stock pocket for under your deck. Those aftermarket ones suck. It's a hole just barely big enough to fit your fingers in. If you ever put something small in there and it slides all the way to the bottom just forget about it. I'm going to check majestichonda.com for one right now to replace my shitty aftermarket one.
Old Sep 26, 2004 | 03:57 PM
JDMFreak's Avatar
Default Re: (EK JayJimenez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK JayJimenez &raquo;</TD></TR><TR><TD CLASS="quote">your only gonna have 1 in your car.. Whhat?? do u want both??for what..when just the cd deck does both.. ur not gonna have both in ur car...its only 1 </TD></TR></TABLE>
if im understanding on what your saying is that he has 2 deck one is a radio with a cd controller and the second deck is the cd slave unit which has eject button only
Old Sep 26, 2004 | 04:01 PM
Default Re: (JDMFreak)
yeah thats right i wonder why cars are made with cd players like that i could understand if it had a casset player but mine doesnt but i dont want to waste anyone elses time i tried burning slower and it seems to work but i still want to get my cd player changed and i learned about trays so thanks but im ok now
ecahatch's Avatar
Senor Miembro
my factory reads burned cd-r's
it's pretty much all in one...the top part(cd slot) is plugged into the bottom one(radio control and other ****)
same goes with any other factory cd player...b/c my si cd plyr came with a cassete deck and it plugs in the cd player...but they are two different units
hybrid90
May 6, 2014 07:35 AM
jdmcd7_cali-luv
Dec 19, 2008 02:05 PM
sell_out85
Feb 24, 2008 06:06 PM
Bone Stock
Nov 17, 2005 11:39 AM
