89 DX Hatch, Blew ZC, Putting SOHC VTEC, What ECU? ? ? Will current PG7 work
Old Sep 25, 2004 | 05:03 PM
The DX Rex's Avatar
Default 89 DX Hatch, Blew ZC, Putting SOHC VTEC, What ECU? ? ? Will current PG7 work
wut up honda tech.
this was my set up.
89 hatch dx
dohc zc swap, stock dx tranny
the zc motor is blown now, so i have a d16z6 from a 94 ex coupe. now should i get another ecu or will the pg7 i believe it is, it is an integra ecu, will it work well or wut is the best? im using some sort of rpm window switch to activate the vtec.
Old Sep 25, 2004 | 05:37 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: 89 DX Hatch, Blew ZC, Putting SOHC VTEC, What ECU? ? ? Will current PG7 work (nyhustla2k)
that should work fine, thats gonna be my setup. this way you can stay obdo, but down the line, u may wanna convert to obd1.
Old Sep 25, 2004 | 05:59 PM
peiku's Avatar
if you plan to stick with the sohc vtec, i suggest you send the odb0 ecu to zdyne. they will make it into a one wire vtec ecu.
stemiched
11
Nov 20, 2006 08:09 PM
btcca4
Jul 1, 2004 09:03 AM
ceLtic
20
Feb 18, 2004 06:34 PM
