Questions about Smog...
Hey Everyone,
I am looking to purchase another integra because mine was just totaled. I found one, but it is in Florida. My main concern is if it will pass California Emissions. Also, if there is anything else that I need to be looking out for. These are the performance modifications done to the car:
It is a 99 LS Coupe
-'98 Ls head with ported/polished/shaved .0015 (7K miles new
-Crower titanium springs/retainers (7K miles new)
-Crower stage 2 60203 intake cam (have stock one also)
-Clutch Masters 12lbs. lightened flywheel (7K miles new)
-Clutch Masters stage 3 full Clutch assembly (7K miles new)
-Jackson Racing polished and engraved cam seal
-Jackson Racing 160 degree F* Thermostat
-Jackson Racing Super Charger running 7 1/2 psi Boost w/ B20 crank pulley
-Kamakazi 4-1 Ceramic header with custom 2.5" flange
-Flowmaster 2.5" race cat w/ flex mesh pipe connectors
-Greddy Evo full Catback exhaust
-Iceman Intake custom cut for JRSCer and Black heat coated
-Nology Red Hot Wires W/ grounding straps
-AEM Red 2 cam gears
-AEM Red Power steering Pulley
-AEM Red Fuel Rail
-AEM Red Fuel Filter housing
-AEM Red Fuel Pressure Regulator
-B&M Oil cooler and filter relocation kit (mounted 100%, Just needs to be connected)
-OBD II to OBD I Kenji conversion harness
-OBD I P28 ECU chipped for 440cc injectors
-Hondata 2b on board engine management box
-RC Engineering 440cc injectors
-NGK BKR7E-11 spark plugs
Thanks a lot!
-Shehzad
It is a 99 LS Coupe
-AEM Red Fuel Rail
Thanks a lot!
-Shehzad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shehzad32 »</TD></TR><TR><TD CLASS="quote">Would you know what I would need to swap out to make it pass smog?</TD></TR></TABLE>
Everything that does not have C.A.R.B. sticker on it.
Possibly the easiest solution to driving an illegal car in this state is to become good friends with a mechanic who will get you a smog cert no matter what's on it. i.e. putting a stock teg on the machine and putting your vin in the computer.
oh ok...I need to go make some friends at smog shops now! The owner of the integra has the carb legal stickers for everything, but I am not sure if the Cams and race cat pipe is legal, and same witht he header, and also the hondata...i can always swap the headers and get the DC carb exempt. I dont know to much about the cams & hondata though.
Modified by Shehzad32 at 11:33 PM 9/25/2004
send2artem
Feb 11, 2011 03:45 PM
