How well do your aggressive built motor start up.
Old Sep 25, 2004 | 11:19 AM
rjay8604's Avatar
Default How well does your aggressively built motor start up.
I was looking for a thread on how built all motor start-up is. Does your motor fire right up every time, or is it rather difficult to start up, is it harder in certain weather. Thanks for responses.
Old Sep 25, 2004 | 11:24 AM
b19coupe's Avatar
Default Re: How well does your aggressively built motor start up. (rjay8604)
Starts up the first time every time
Old Sep 25, 2004 | 02:35 PM
vtecdamian's Avatar
Default Re: How well does your aggressively built motor start up. (b19coupe)
crank crank vroom
Old Sep 25, 2004 | 02:56 PM
DOHCtorTHRUST's Avatar
Default Re: How well does your aggressively built motor start up. (vtecdamian)
mines did the first crank...but its far from agressive...
Old Sep 25, 2004 | 08:31 PM
rjay8604's Avatar
Default Re: How well does your aggressively built motor start up. (DOHCtorTHRUST)
well, people with "big" cams and high compression, maybe ITB's make it harder to start too, i guess i'll find out.
Old Sep 25, 2004 | 09:52 PM
itralex's Avatar
my car starts up fine in the cold or in the heat
it just has trouble starting after i completely fill up the tank with gas. It goes like, crank crank crank crank crank crank crank crank then it goes blop blop blop blop blop blop until you rev it up to keep it running or it'll die
Old Sep 25, 2004 | 10:13 PM
OLM-02R's Avatar
starts up first time... vrooom
Old Nov 26, 2005 | 09:41 PM
rjay8604's Avatar
Default Re: (OLM-02R)
Just thought i'd add. Since my build is done and its pretty cold out. It takes a few cranks to start in the cold, i'm also using the tiny hawker/odyssey battery. I have to give some gas for a few seconds when its real cold or it'll die. No big problems though.
Old Nov 26, 2005 | 10:02 PM
sleepycivichb's Avatar
wow. back from the dead. "vtecdamian" isn't even a user anymore. haha
Old Nov 26, 2005 | 10:06 PM
PirateMcFred's Avatar
Default Re: (rjay8604)
My 12.25CR 2.3 liter with aggressive nonVTEC cams takes a little longer to start when it is cold out but nothing I'd consider excessive. I use the stock starter and a Odyssey PC680 too.
Pirate
Old Nov 26, 2005 | 10:18 PM
xEnderx's Avatar
Default Re: (PirateMcFred)
12.5 CR S2S3 cams. I only had it back for a day before it got sent back in for a dyno tune. It didn't really start worth a crap on the stock ECU (SVO 450 CC injectors), and the AEM base map I was using wasn't really compatible with the motor.
Old Nov 27, 2005 | 06:01 PM
d16dcoe45's Avatar
Default Re: (xEnderx)
13:1 1.8 d16a6--Gude Gorilla cam, dual Weber carbs--starts on 4 or 5 crank even in cold weather. Using Odyssey PC 540 battery and stock starter.
Old Nov 27, 2005 | 08:56 PM
rjay8604's Avatar
Default Re: (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">13:1 1.8 d16a6--Gude Gorilla cam, dual Weber carbs--starts on 4 or 5 crank even in cold weather. Using Odyssey PC 540 battery and stock starter. </TD></TR></TABLE>
Nice crazy setup. I'm using that battery too.
jackstands
Mar 13, 2005 08:54 AM
