shes up and running
Old Sep 25, 2004 | 08:28 AM
adler's Avatar
Default shes up and running
sweet ***, i got my 91 civic back up and running. you may remember it from such threads as: https://honda-tech.com/zerothread?id=995125
what i did was i talked to a honda tech the other day and he said the coolant temp sensor may have hiccuped. the ecu thought the engine needed more gas since the motor was cold and tried to fast idle and flooded the engine. there was probably too much gas and it was wetting down the compression. he said shoot some oil in the cylenders and try it, and it started right up.
now my question is have any of you seen this before? and should i then replace the coolant temp sensor. and what if that wasnt even the problem? how do i stop it from happening again?
Old Sep 25, 2004 | 09:20 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: shes up and running (adler)
That is why I asked: 'What do the spark plugs look like?'..
Even though the plugs are "new",they won't fire if they are soaked with gas..
My friends truck just had the same problem..
We replaced the sensor and the connector on the harness because it
looked like someone shoved a meter probe into it
and the terminals were "stretched out.."
I have seen it several other times as well..
At any rate,Glad you got it going..
Old Sep 25, 2004 | 09:24 AM
EL Vap133's Avatar
Default Re: shes up and running (88DXCRX)
Listen to Phil, he knows his ****.
96blk_vr
Jan 30, 2014 10:13 AM
stocker2shocker91
Nov 2, 2012 06:45 PM
UnderConstruct95ex
Acura TSX
Jan 4, 2012 07:37 PM
Bowl_of_Rice
Mar 11, 2011 05:32 PM
aziantegger10
Apr 8, 2005 03:05 PM
