sway bars on a std?
Old Dec 11, 2001 | 06:25 PM
Mugen Dom's Avatar
Default sway bars on a std?
how do i do it there has to be a way all teh holes are there but no nuts welded in there butt there isnt a way to get a nut in there i want to get them in there from teh 93 teg ive got for parts help please
Old Dec 11, 2001 | 09:20 PM
REDBARON's Avatar
Default Re: sway bars on a std? (DOHC DX)
Do you have a civic hb std? Because I do and I installed the CRX si rear sway bar without any hassle. It just bolted right up. All I needed was the Si's LCA's and the complete sway bar with all the brackets and bolts. Very simple swap. You should already have the holes there and all you do is screw the bolts in.
Old Dec 12, 2001 | 03:39 AM
Mugen Dom's Avatar
Default Re: sway bars on a std? (VTECHatch)
well im gonna try it with the stock control arms there arent to many 88 si's around and there are holes there any how
Old Dec 12, 2001 | 03:47 AM
TypeR0207's Avatar
Default Re: sway bars on a std? (jdmB18hatch)
Buy the Eibach or Suspension Techniques bars, better and some adjustability.
About $200 (almost the same as getting the control arms, etc.).
Old Dec 12, 2001 | 03:55 AM
Mugen Dom's Avatar
Default Re: sway bars on a std? (TypeR0207)
see i have a 93 teg that im taking the sway bars off i just need to get the mounts from a si so im gonna have to visit a buddies junkyard and see if i cant find a si in the back hopefully my lower control arm works with them it should the 88 control arm is diff than all the other EFs so thats y i cant use other control arms how much a difference will i see with them in teh front and back being the std wasnt blessed with either
griffinjr123
Suspension & Brakes
Nov 16, 2009 02:53 PM
bluestd
Aug 8, 2009 08:49 AM
hatch is best
Nov 9, 2006 11:16 AM
Peters1983
May 29, 2003 10:21 AM
v88dx
Mar 28, 2003 02:48 AM
