question on welding settings
Old Sep 24, 2004 | 11:41 PM
hatchback_al's Avatar
Default question on welding settings
i need to rotate a flange on my exhaust, i cant get it to line up. My plan is to cut the exhaust pipe about 2 inches behind the flange and then rotate and weld it back on. i have an aftermarket stainless steel exhaust. im wondering what kind of setting i should set my wire feed welder too. its a medium sized one with gas and all that, not a little hobby welder or anything. thanks a lot guys. any pointers would be great.
Old Sep 25, 2004 | 05:43 AM
david@didrace.com's Avatar
Default Re: question on welding settings (hatchback_al)
A make and model number would help. Also what thickness is the piping?
Best bet is just to get some metal that is the same thickness as what you need to weld and try out different settings on that before hand. Use stainless steel wire if possible so the welds won't rust.
Old Sep 25, 2004 | 12:23 PM
Canuk_SiR's Avatar
try to find out what kind of stainless you've got, and get the proper wire for your application.
Old Sep 25, 2004 | 12:45 PM
TeamNextGenChris's Avatar
not to discourage you,but it sounds like you're pretty inexperienced when it comes to welding-you may be better off to go ahead and cut the pipe,mark the correct orientation,then take it to a muffler shop to be welded.i wouldn't think anybody would charge you more than $10.
knowing how to weld is a great skill to have,but this would be an expensive part to be your learning project.i'd recommend,as said above,at least getting some scrap metal(preferably of the same thickness as your header)and learn on it first.
Chris
Old Sep 26, 2004 | 08:42 PM
Default Re: question on welding settings (TeamNextGenChris)
i have plenty of experience welding, and am pretty good at it (not to brag). The thing is, everytime I use this welder my buddy has, it just doens't work right for me. The welds come out really really shitty. The exhaust is T-304 stainless steel and is maybe an 1/8" or so thick. Your basic aftermarket stainless exhaust. Its a 91 civic......
Old Sep 27, 2004 | 03:21 AM
assuming the welder is decent quality,and functioning properly,it sounds like you need to play with the wire speed and/or heat settings.get some scrap stuff and play around until you get it set up right.
Chris
Old Sep 27, 2004 | 09:25 AM
Brandon Clifton's Avatar
I SERIOUSLY doubt your exhaust is 1/8" thick. Most likely it's .050"- maybe .062", but I doubt it.
If your buddy has a gasless welder that explains why you're having problems welding with it.
As for your application, rule of thumb is 1 amp per ten thousandths (ie 5 amps for .050"). Make sure your cut is perpendicular to the axis of the pipe or you're going to end up welding two ellipses back together instead of two circles. Just tack it in three or four places before you try to lay the whole bead on so the gap doesn't pull apart as you move around the pipe.
Old Sep 27, 2004 | 10:23 AM
Default Re: question on welding settings (Brandon Clifton)
ok, bad guestimate on my part But the welder is pretty decent and has a gas tank attached, its not a little play welder Is there anything I should set the gas tank to? Or just open it and your good. I noticed there is an adjuster so what should I adjust it to?
uberEFtuner
Welding / Fabrication
Sep 6, 2011 09:05 AM
silly nanny24
May 4, 2010 05:51 PM
downest
Oct 7, 2009 08:02 PM
turbotime
Apr 15, 2006 12:14 AM
sleepystyle
Apr 1, 2006 09:24 PM
