82mm Ok on B16?
Old Sep 24, 2004 | 10:00 PM
JDMlyfestyle's Avatar
Default 82mm Ok on B16?
I was just wondering if boring out the B16 to 82 mm would be safe. i plan to rev the motor up to or a little more than 9k with BC spec 3's and 12:1 C/R.
Old Sep 25, 2004 | 12:15 AM
Pondus's Avatar
Default Re: 82mm Ok on B16? (JDMlyfestyle)
Yes it is ok.
Old Sep 25, 2004 | 01:06 PM
anyone else?
Old Sep 26, 2004 | 07:08 AM
hotintegranights's Avatar
Default Re: (JDMlyfestyle)
its ok with the stock rev limit, and honda even aproves of 81.50mm. but your reving past 9rpm,i would not recomend it at all, if you reving that high i would go with some 81.25mm. or just sleeve the motor and get the best results.
Old Sep 26, 2004 | 08:03 AM
Seth21's Avatar
Default Re: (hotintegranights)
I would not bore to 82mm without sleeving it i run 84mm on GE sleeves
Old Sep 26, 2004 | 08:23 AM
asubennett's Avatar
Default Re: (550whp)
If this is a drag car only. I say go for it.
If this i your daily driver where reliability effects your life stay @ 81.50mm
AllMotorKiDD
66
Aug 14, 2012 07:13 AM
ceLtic
12
Mar 24, 2005 09:09 AM
kaoss_11
Dec 2, 2004 12:12 PM
kaoss_11
13
Dec 2, 2004 11:19 AM
af97civic
Dec 2, 2003 04:31 PM
