clutched slipped! will it be okay?
Old Sep 24, 2004 | 09:13 PM
sinister357's Avatar
Default clutched slipped! will it be okay?
i was in a hurry today and reved the engine quite high (4-5K) before releasing the clutch. instead of the wheels squeling, the clutch slipped all the way in first gear to red line. smelled kindda funny afterward but it seemed to be operating normal now. did i do any damage to the clutch? will it have the tendency to keep slipping now that's happened? it's a fairly fresh clutch.
Old Sep 24, 2004 | 10:21 PM
ckyguy's Avatar
it's not good for the clutch, but if it's still fairly new and still grips alright it should be fine, just do do that too often
Old Sep 24, 2004 | 10:30 PM
Accord2NR's Avatar
Default Re: clutched slipped! will it be okay? (sinister357)
some people actually do it all the time, i think its called having a heavy foot, but dont worry itll be fine
Old Sep 24, 2004 | 11:00 PM
viet's Avatar
Default Re: clutched slipped! will it be okay? (AcuraINTEGRAGSR)
fairly fresh clutch? then youre good to go. just don't do it too many times
Old Sep 26, 2004 | 04:08 PM
Default Re: clutched slipped! will it be okay? (viet)
thanks for your feedbacks, guys. now i'm not so worried anymore. (just alittle bit still) so this has happened to you all before and no problem huh? cool... i won't do it again though. i promise foreal!
Old Sep 26, 2004 | 04:11 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister357 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for your feedbacks, guys. now i'm not so worried anymore. (just alittle bit still) so this has happened to you all before and no problem huh? cool... i won't do it again though. i promise foreal! </TD></TR></TABLE>
u dont need to promise us.. make sure you promised yourself. and just becareful.
what kind of clutch was it by the way? stock or aftermarket and how new/old is it?
Old Sep 26, 2004 | 04:35 PM
Default Re: clutched slipped! will it be okay? (..::91TEG-G2::..)
i'm assuming it's an oem or equivalent clutch. the car (a gsr) is completely stock so i doubt it that it's a performance aftermarket clutch. i've just recently bought the car and i was told both the timing belt and clutch are within a few months old so it should be good for at least 20 - 30k or so miles. i will get it upgraded eventually but not unless i have to because it's working great now (most of the time).
jdmstyleEJ6
12
May 9, 2010 04:13 PM
Curtisbeef
Sep 15, 2004 03:00 PM
Flux
Nov 26, 2003 11:25 PM
JDEM1
Jan 28, 2003 11:07 PM
pr0digy1
Apr 18, 2002 09:59 AM
