Where to drill on a lip?!? need help asap!
Old Sep 24, 2004 | 05:41 PM
nichols_si's Avatar
Default Where to drill on a lip?!? need help asap!
k on a lip like this one:
where do i put the 4 screws in that it came with?
Old Sep 24, 2004 | 05:44 PM
Nova_Dust's Avatar
2 per each side, on the bumper. The part that face your front wheels.
I suggest you try to make some custom L bracket holder below centre of the bumper, so it won't sag over time.
Old Sep 24, 2004 | 06:05 PM
Shaun's Avatar
get yourself, some self starting screws
Old Sep 24, 2004 | 06:11 PM
mugensport9's Avatar
Default Re: (Shaun)
here ya go
http://www.autodynamic.com/tra...r.htm
Old Sep 24, 2004 | 06:16 PM
OneFire's Avatar
Default Re: (Nova_Dust)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nova_Dust &raquo;</TD></TR><TR><TD CLASS="quote">2 per each side, on the bumper. The part that face your front wheels.
I suggest you try to make some custom L bracket holder below centre of the bumper, so it won't sag over time.</TD></TR></TABLE>
How do you make those??? have a link with pictures of anything???
Old Sep 26, 2004 | 12:06 PM
Nova_Dust's Avatar
If you can make an L or better yet, a U bracket out of thin metal, bolt one end to the bottom of the bumper, and the other to the bottom of the lip, I say 4 evenly spaced out should be good. OEM lip has like what, 8 of those spread out?
That goes the same for rear lips. I hope this helps.
Old Sep 26, 2004 | 12:38 PM
GUNNER666's Avatar
i'll go take a pic of where i put my screws,
i'll post em up in a minute
Old Sep 26, 2004 | 12:55 PM
GUNNER666's Avatar
Default Re: (GUNNER666)
i put 2 like this on each side, then i put 3 underneth the front of the car basically where the stock bolts came out. you'll see a place that set screws will be able to go. i used 7 in total, and no 3m tape.
Old Sep 26, 2004 | 02:42 PM
OneFire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUNNER666 &raquo;</TD></TR><TR><TD CLASS="quote">
i put 2 like this on each side, then i put 3 underneth the front of the car basically where the stock bolts came out. you'll see a place that set screws will be able to go. i used 7 in total, and no 3m tape.</TD></TR></TABLE>
your link no work?
Old Sep 26, 2004 | 04:25 PM
HuggerHatch's Avatar
Yo just mounted my brothers carbon lip on his hatch and we did the same thing, 2 screws on each side of the lip, near the tire. You may have to turn the wheel to the left and right to get a drill in there to drill a piolet hole first so you dont crack the fiberglass. When your done with doing that on both sides, prop up with middle with a shoe box or something so it dont snap. Got buy some self push in buttons, there cheap and spread the out underneath in 4 different spots and it holes it up better then ant other screw would underneath. Yo make sure you dont drill the hole to big for the buttons ok or it will be to easy to go in and you want it to go in very tight.. iaght man good luck on you lip.. hope it helps 1
CaliStreetWolf
Jul 22, 2013 01:06 PM
lickety_britches
Jun 17, 2009 08:40 AM
whiskaz
Mar 21, 2007 04:00 PM
jaywoodz
Oct 8, 2005 10:24 AM
