Which header/cat to use on EG with B16
Old Sep 24, 2004 | 03:49 PM
Marktwo's Avatar
Default Which header/cat to use on EG with B16
I've searched and searched for hours without finding a definite answer. Will somebody please set the record straight for me? I'm trying to figure out if I ordered the wrong header. I have read on here many times that you need to use an LS header and cat on any B-series swap in EG hatches. This supposedly is the only way to get everything to fit perfectly without having to go to the muffler shop. I have also read that you can use a Del Sol VTEC/99 Civic Si header and cat to get the same result. I need to know for sure because I ordered the Del Sol header already, but no cat.
So which is it: LS header and cat or Del Sol VTEC header and 92-95 Civic cat?
HELP ME PLEASE!
Old Sep 24, 2004 | 07:29 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Which header/cat to use on EG with B16 (Marktwo)
bump for you. Id like to know as well
Old Sep 24, 2004 | 10:34 PM
Marktwo's Avatar
Default Re: Which header/cat to use on EG with B16 (SkoundrelUSA)
up
Old Sep 24, 2004 | 10:52 PM
blaster834's Avatar
to me it would make sense to use a del sol b16 header with a civic cat.
Old Sep 25, 2004 | 12:32 AM
Viorent Grip! EG's Avatar
Default Re: (blaster834)
i use the dynamic autosports jdm header with jdm ITR cat...
works good for me
Old Sep 25, 2004 | 03:31 AM
civic2slo's Avatar
actually if you use the del sol or the jdm eg b16a manifold it will bolt up to your stock catalytic converter. using the factory spring bolts...Now froma performance stand point ...Jdm or dc jdm header will require you to install a after-market cat. or if you car is planning only to be used off road , a straight pipe. but that would require you to go to the muffler shop.
Old Sep 25, 2004 | 07:03 AM
Marktwo's Avatar
Default Re: Which header/cat to use on EG with B16 (civic2slo)
Okay, I see. So the DC 4-1 stainless I ordered for a Del Sol VTEC will bolt up to the Civic catalytic converter? Thanks for the replies.
raylo
Jun 22, 2019 04:48 AM
raverx3m
Mar 1, 2013 10:46 PM
Username001
May 15, 2008 07:03 PM
SOLvtec
Nov 19, 2006 11:04 AM
REDBARON
May 7, 2002 12:56 PM
