what ecu comes with a 92 teg
Old Sep 24, 2004 | 12:54 PM
Stewie's Avatar
Default what ecu comes with a 92 teg
Just like the title says. Can someone give me the code for this ecu?
Old Sep 24, 2004 | 01:01 PM
jdmotorsports's Avatar
Default Re: what ecu comes with a 92 teg (Stewie)
its a obd1 pr4 ecu that came in the 92-93 non-vtec integras. the gsr's came with a p61 ecu.
Old Sep 24, 2004 | 04:02 PM
Cliffjumper2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stewie &raquo;</TD></TR><TR><TD CLASS="quote">Just like the title says. Can someone give me the code for this ecu?</TD></TR></TABLE>
the 90-93 integras came with the PR4 ecu........but beware the 90-91 pr4 ecu and the 92-93 pr4 ecu are different when it comes to the plug sizes. so a 92-93 pr4 won't be a direct plug and play for a 90-91 teg, and vice versa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">its a obd1 pr4 ecu that came in the 92-93 non-vtec integras. the gsr's came with a p61 ecu.</TD></TR></TABLE>
yep, and the 90-91 pr4 ecu is obd-0, and is a good ecu to use if you have an LS swap into a crx......at least that is what I used in my ls/b18a swapped crx in place of the pm6 ecu.
CrazyHigh625
Jul 9, 2012 01:53 PM
94Acura
Sep 10, 2004 04:53 PM
tiresmoke
Feb 26, 2004 10:24 PM
Sohc Driver
Nov 19, 2003 06:03 AM
shermanyang
Aug 18, 2002 04:50 PM
