4.785 Tranny is hard to shift gears.. I need help :(
Old Sep 24, 2004 | 10:33 AM
JDMlyfestyle's Avatar
Default 4.785 Tranny is hard to shift gears.. I need help :(
I thought i would ask the integra forum since the EG forum isnt helping me much. Last night i noticed that it was really hard to shift gears. almost to the point where i would have to force it into gear. I did the 1st to 4th gear and it did not stall. There is no grinding at all from the synchro's. I have it narrowed down to the pressure plate/ throw out bearing/Tranny fluid. So what do you guys think it is.
Old Sep 24, 2004 | 10:56 AM
Spikey's Avatar
Default Re: 4.785 Tranny is hard to shift gears.. I need help :( (JDMlyfestyle)
possibly clutch fluid related... ie. not enough clutch fluid or pressure in the system.
i had a similar situation, it was very hard to get shift gears. it turned out to be a lack of clutch fluid/pressure. the hard line leading into the slave cylinder wasn't sealing properly... there was a micro-fissure on the trumpet end of the line and it was leaking fluid.
Old Sep 24, 2004 | 12:04 PM
.RJ's Avatar
.RJ
Default Re: 4.785 Tranny is hard to shift gears.. I need help :( (Spikey)
if the lines are fine, then the clutch disc or pressure plate is busted
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
ramos2589
Feb 10, 2008 08:58 PM
EG2Driver
Oct 16, 2006 03:49 PM
honda4674
Oct 24, 2005 07:39 AM
SnkyPY
Dec 11, 2003 09:16 AM
