FS: Fully built 2.1L N/A ITR swap, with extras
Guest
Posts: n/a
2.1L ITR engine:
92mm Crower crank
custom spec Carillio A-beam rods
Custom, coated Weisco pistons (NO WHERE CLOSE to shelf stock...at all)
all new oe bearings and gaskets
ARP head studs
Cometic headgasket (thick for break in)
SRR cam gears
new oe timing belt
RLZ stage 3 cams (HUGE)
RLZ single springs
RLZ titanium retainers
RLZ mild port work
RLZ assembled
JDM ITR manifold, portmatched to 70mm
70mm STR throttle body
REAL Top Fuel Power Chamber #1 intake
custom, black, billet, big bore fuel rail
390cc and 450cc DSM injectors
B&M fpr
s4c tranny (99-00 si):
NEW kaaz LSD
NEW oe 3/4 kit
NEW oe countershaft bearing
ACT Xtreme Pressure plate
custom 6 puck, unsprung, lightweight clutch disk
Clutchmasters aluinum flywheel
C&R 3/4 length aluminum radiator
Espiler JGT500 cat back exhaust
Cusco catch can
AN-R compact, merge, coated header
stock axles and intermediate shaft
JDM ITR shift linkage
JDM ITR shifter
NASCAR shift ****
old schoo l Honda 6 speed **** (from awd wagon with 1-5 and ultra low)
uncut, stock VX wiring harness
cut JDM ITR wiring harness (to convert the VX to work)
2 1/16 Autometer procomp ultralite Oil pressure and water temp gauges, both electric with senders and other ****
Chipped ecu, RTP, uberdata, 2-step
IBM T20 laptop for tuning
93 VX parts car (
4 VX wheels
4 NEW 155/80/13 tires (basically skinnies that work for the street too)
13x8 weld Magnums with 24.5/8 MT's
OE hubs with extended wheel studs
uber light aluminum lug nuts (blue!)(UUUBER rare)
radiator hoses
stock ITR fuel rail
OE JDM ITR air box with JDM monster flow filter (JDM Y0!!! )
this is BRAND new....0 miles...never cranked, never run, never beat, never raced, etc.............
should make around 230whp with proper tuning, on 93 octane. More power could be made if you swapped out the thicker Cometic for a thinner (0.30) which will tkae you from the present 11.5:1 to right at 12:1.
this is a 50K+ mile engine
it's built to be a DAILY DRIVER, and enjoyed...while possibly hitting LOW 12's/high 11's on the provided slicks....with a GOOD driver and a light chassis.
asking $12,500 for it ALL....
in NC, and would PREFER for it to stay close...for ease of transaction
Modified by NAstreetEH2 at 5:23 AM 9/25/2004
92mm Crower crank
ARP head studs
SRR cam gears
new oe timing belt
RLZ single springs
RLZ mild port work
RLZ assembled
B&M fpr
NEW kaaz LSD
NEW oe 3/4 kit
Cusco catch can
JDM ITR shifter
NASCAR shift ****
93 VX parts car (
)4 VX wheels
radiator hoses
stock ITR fuel rail
you need to space that **** out rob. i doubt people are catching that there is a POS eg shell included in there among other things like slicks/wheels worth over 700
blykins
Jun 27, 2004 07:53 PM
