How much does GSR 97's crank pulley weight?
Old Sep 23, 2004 | 10:16 PM
yeegsr's Avatar
Default How much does GSR 97's crank pulley weight?
how much does it weights in term of lbs or kg...w/out the bolt or with bolt anyone know
i have the original acura manual but couldn't the spec for my the weight and stuff...too many pages to flip if anyone know thankx alot
Old Sep 23, 2004 | 10:18 PM
W.O.P.'s Avatar
Default Re: How much does GSR 97's crank pulley weight? (yeegsr)
why?
Old Sep 23, 2004 | 10:33 PM
95 integra's Avatar
Default Re: How much does GSR 97's crank pulley weight? (1quickLS)
5lbs?
Old Sep 24, 2004 | 01:06 AM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS &raquo;</TD></TR><TR><TD CLASS="quote">why?</TD></TR></TABLE>
because after diameter vs stock + weight = how much different in term of gain...
are you sure 5lbs? that's alot...
Old Sep 24, 2004 | 05:40 AM
stareatsun's Avatar
its heavy for a reason.
with the weight it takes strain off the crank and also allows for you not to rev the **** out of a stock motor. with a lightened crank and other pullies, you wear on the crank bearings faster causing problems down the line.
Old Sep 24, 2004 | 05:56 AM
IN VTEC's Avatar
Old Sep 25, 2004 | 12:56 AM
yeegsr's Avatar
Default Re: How much does GSR 97's crank pulley weight? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
oh sweet man..thanx a lot.....you the man
wesley_925
22
Apr 15, 2008 10:07 PM
turbodohcsi
Oct 4, 2007 02:00 AM
turbotime
Mar 31, 2006 05:59 AM
mdixonjam
Jul 3, 2005 09:59 AM
