Need help. '94 GSR...trouble starting.
This is what happens. I turn the key and press the clutch....the motor turns, but no start. It turns and turns. I wait 1min and then it starts. Sometimes it starts and bogs out a couple of times. Can this be a bad fuel pump? My clutch is practically out also..can it be the clutch? I already changed the fuel filter. Any suggestions.
i would highly reccomend pulling a plug and checking to see if there is any signs of fouling. you can read alot about an engine from a plug. if it just cranks and cranks it probably is your distributor. too many variables to tell. you might wanna get your car diagnosed at a auto-electric shop.
charlieboyhonda
20
Jul 3, 2009 09:23 PM
cnh4
Aug 20, 2004 06:04 PM
