Need ECU advice... h22 all motor
Old Sep 23, 2004 | 05:43 PM
juicedh22's Avatar
Default Need ECU advice... h22 all motor
Hey, i have an h22 with the following..
type s pistons (a4 open deck block)
skunk2 stage 2 cams
skunk2 cam gears
skunk2 retainers and v. springs
skunk2 intake mani
Edelbrock 65mm TB
ferrea valves
manual tensioner
aem fuel rail
aem fpr
aem intake
greddy header, exhaust
hight flow cat
sci ignition
msd blaster ss coil
msd wires
vafc, p13 and p72 (not that these matter depending on what advice i get)
So what i would appreciate help on is my ECU choice. Any advice on what would work best with my setup without dropping high dollar such as aem ems. I have looked at greddy emange, a used hondata setup (should i go p72 or p28) these are the things i need info on. What is your ecu choice?
Modified by juicedh22 at 10:27 PM 9/23/2004
Modified by juicedh22 at 10:45 PM 9/23/2004
Old Sep 23, 2004 | 06:21 PM
GOLDBERG's Avatar
Default Re: Need ECU advice... h22 all motor (juicedh22)
you using stock intake manifold?
Old Sep 23, 2004 | 06:27 PM
juicedh22's Avatar
Default Re: Need ECU advice... h22 all motor (GOLDBERG)
whoa, thanks, i nearly forgot to mention my addition of the skunk2 intake mani
Old Sep 24, 2004 | 03:30 AM
93H22ACX's Avatar
since you already have a skunk2 IM, go with a less expensive ecu like the P28 and get hondata s100 if you dont want to spend a little extra for a s200
juicedh22
Apr 19, 2005 08:43 PM
cancer
May 28, 2004 08:06 AM
explosive
Nov 8, 2003 11:06 PM
sleepycivix
Feb 7, 2003 11:24 PM
