D15B Vtec wiring
Old Sep 23, 2004 | 05:30 PM
CRXalwysk8's Avatar
Default D15B Vtec wiring
the new obd1 injectors, the four different colored wires stay the same but what abou tteh red wires that used to go to the resistor box, they go to the yelow wire fromt eh resistor box????thanks
Old Sep 24, 2004 | 06:53 AM
CRXalwysk8's Avatar
Default Re: D15B Vtec wiring (CRXalwysk8)
help meee
Old Sep 24, 2004 | 07:22 AM
crx_88_si's Avatar
basically u have to bypass the ressitor box.
or you could use 88-91 injectors w/ resistor box on the obd1.
Old Sep 28, 2004 | 07:07 AM
CRXalwysk8's Avatar
Default Re: (crx_88_si)
What about the purge control valve thingy that used to be on the firewall with the map sensor, i know you use the new map sensor on the throttle body, but what about the purge valve, do you just bypass taht, do you use it or not??? andddd what about the plug near the thermostat, my d15b2 didnt have it, but the d15b vtec has it??? thanks guys
Old Sep 28, 2004 | 07:18 AM
CRXalwysk8's Avatar
Default Re: (CRXalwysk8)
bump
Old Sep 28, 2004 | 07:22 AM
crx_88_si's Avatar
ok.. near the oil filter on the obd0 block is a two prong plug. in 92+ they moved this sensor to where the t-stat is. so extend the wires and swap for a plug that fits.
the purge you can just use the obd-0 one or bypass it. it doesnt effect performance, just emissions.
Old Sep 28, 2004 | 04:04 PM
CRXalwysk8's Avatar
thanks man, sounds good. anyone have any good pics or diagrams for teh vacuum routing on a d15b vtec in a crx?? thanks
travishoward
Aug 12, 2010 05:41 PM
shortbuss90
Apr 8, 2008 12:09 PM
haroldthefly91crx
Sep 9, 2006 12:56 PM
Fusion G2 Civic
14
Dec 22, 2005 09:49 AM
spun Vtec
10
May 12, 2003 06:21 PM
