How hard to put front camber kit on ?
Old Dec 11, 2001 | 01:04 PM
96IntegraLS4DR's Avatar
Default How hard to put front camber kit on ?
Will I need spring compressor ?
Will I need to take out the axel ?
Thanks in advance.
Old Dec 11, 2001 | 03:53 PM
ingrate's Avatar
25 Year Member
Default Re: How hard to put front camber kit on ? (96IntegraLS4DR)
it's pretty easy. just use regular hand tools. remember to get an alignment after you do it
Old Dec 11, 2001 | 09:48 PM
wreckedagain's Avatar
Default Re: How hard to put front camber kit on ? (In7egrity)
its exteemly easy no you dont need those tools just 17mm 14mm and few other minor tools but make sure you deinitely get that alignment
Old Dec 12, 2001 | 12:50 AM
CyBeRnUtZ's Avatar
Default Re: How hard to put front camber kit on ? (wreckedagain)
How easy is it to adjust a camber kit, or is that only a job for the alignment shop.
Old Dec 12, 2001 | 07:54 AM
Thanks for all the relies.
Thanks.
Old Dec 12, 2001 | 07:56 AM
dynamite C1's Avatar
Default Re: How hard to put front camber kit on ? (CyBeRnUtZ)
I will be anticipating for a reply on this one...
Old Dec 12, 2001 | 12:10 PM
keys's Avatar
Default Re: How hard to put front camber kit on ? (dynamite C1)
to install a camber kit it's really easy.... you can adjust your camber kit really easily too, but unless you have an instrument that can measure camber, i doubt you will be very accurate.... so when you get an alignment you should tell them what settings you want your camber kit adjusted to.......
also, make sure you lubricate your camber kit very well to prevent squeeking....... it's a pain in the butt to lubricate them when they are already installed
hatch_
Feb 10, 2009 09:25 PM
itsJDMyo
13
Jan 7, 2005 10:40 AM
JDMTurboEG6
Mar 11, 2004 07:53 PM
dom93hatch
Apr 19, 2003 10:26 PM
