Rear Lower Tie Bar 5th gen
Old Sep 23, 2004 | 03:18 PM
DoriEK's Avatar
Default Rear Lower Tie Bar 5th gen
I am having a problem getting the bolts off the the contol arms. I have drenched both bolts with some wd40. I also even tried to use 1 inch impact gun on the bolts and they did not even budge. Thanks foe the help.
Old Sep 24, 2004 | 04:10 AM
luderacer's Avatar
Default Re: Rear Lower Tie Bar 5th gen (DoriEK)
Your bolts could be rusted so thats why its not moving. Its going to be very hard if not impossible to get those bolts off if its rusted. If you live up north and drive in snow and salt, that could cause the problem.
Old Sep 24, 2004 | 05:21 AM
Shakes's Avatar
space cadet
Default Re: Rear Lower Tie Bar 5th gen (luderacer22)
is your new best friend
Old Sep 25, 2004 | 03:11 PM
luap's Avatar
Default Re: Rear Lower Tie Bar 5th gen (Shakes)
will that lube work???
Old Sep 25, 2004 | 03:55 PM
lOOkatme's Avatar
breaker bar....put a pipe over the wrench your using and torque down on that bolt
DEATHB4DlSHONOR
Mar 1, 2010 03:53 PM
Parker.
Suspension & Brakes
Sep 24, 2007 05:46 PM
Edulerp
Jul 2, 2004 05:53 PM
96civich22
Apr 5, 2004 05:25 PM
ZALKU
Apr 8, 2002 05:21 PM
