Should I replace the tensioner spring?
Old Sep 23, 2004 | 12:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Should I replace the tensioner spring?
My car is about to hit 180,000 miles, and this weekend I will be putting on the car's 3rd timing belt, along with a new water pump, tensioner pulley, camshaft seals, front main oil seal, new spark plugs, fuel filter, etc.
Unfortunately when I was ordering parts I did not think to order a new tensioner pulley spring. Should I replace it since I do have nearly 180K miles? I can't get one before this weekend, maybe replace it later on when I have a chance?
Old Sep 23, 2004 | 04:58 PM
tremor86's Avatar
Default Re: Should I replace the tensioner spring? (PatrickGSR94)
I am a tech at an acura dealer and everytime we recommend a t-belt service, we recommend replacing the spring. They really do loose their tension over time and it will be hard to get the tension set correctly when finishing everything up.
Old Sep 23, 2004 | 06:15 PM
Drian's Avatar
Of subject, 180k!!!! I thought I had high miles. I have 155k on my '94 GSR. And yeah, replace the tensioner spring. I just ordered it. I'm also gonna do the timing belt/waterpump/tensioner/spring....etc. Good Luck!
Old Sep 23, 2004 | 06:16 PM
Community Builder
Default Re: (Drian)
crap, I can't get one before this Saturday, and I'm at 178,500 now, I'll be past 179K before next weekend.
NO dealers around here stock it.
Old Sep 23, 2004 | 06:20 PM
CNSK's Avatar
Default Re: (PatrickGSR94)
damn...its your third time replacing a timing belt?? I have a 95 gsr and it has 170k miles and never changed timing belt, water pump, or my old beat up clutch.....I need to though. Knock on wood...before it snaps on me....but defenitly my clutch squeeks big time (only on 1st gear when Im balancing out my clutch and gas pedal) and its pretty embarrasing.....
Old Sep 23, 2004 | 06:44 PM
Community Builder
Default Re: (Moua)
no, this will be the 3rd timing belt I'm putting on the car... only the 2nd water pump, though, it's currently still on the original water pump.
Old Sep 23, 2004 | 06:53 PM
bdkrma's Avatar
180K...you should be on your 5th TB. I always do the WP, ans tensioner at the same time. save headaches/trouble/time in long run
walrus0
Honda Civic (2001 - 2005)
Sep 13, 2012 09:56 PM
chad_nishikawa
Jan 9, 2011 03:44 PM
EGgoJDM
May 13, 2010 03:32 PM
Lambo123
Sep 7, 2009 10:25 AM
OH_1fstgsr
Mar 7, 2007 10:13 AM
