Where to get velocity stacks?
Old Sep 23, 2004 | 11:14 AM
89civic1.8T's Avatar
Default Where to get velocity stacks?
Does anyone sell em? Looking to make an intake manifold.
Old Sep 23, 2004 | 02:23 PM
OverCenter's Avatar
Default Re: Where to get velocity stacks? (89civic1.8T)
Kinsler Fuel Injection
Troy, MI
Old Sep 23, 2004 | 08:23 PM
tony1's Avatar
Default Re: Where to get velocity stacks? (kevinatCandR)
TWM has them as well, just bought some from them 2 days ago.
Old Sep 24, 2004 | 03:29 PM
Full-Race Geoff's Avatar
we have some, we are making huge runs right now, here are some pics of the unfinished parts
Modified by Full-Race Geoff at 7:53 PM 9/24/2004
Old Sep 25, 2004 | 02:15 PM
stealthhatch's Avatar
Default Re: Where to get velocity stacks? (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">we have some, we are making huge runs right now, here are some pics of the unfinished parts
Modified by Full-Race Geoff at 7:53 PM 9/24/2004</TD></TR></TABLE>
im looking for something similar to this for brake ducts anybody know what to use and where to get them?
Old Sep 25, 2004 | 02:22 PM
89civicdx's Avatar
Default Re: Where to get velocity stacks? (stealthhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthhatch &raquo;</TD></TR><TR><TD CLASS="quote">im looking for something similar to this for brake ducts anybody know what to use and where to get them?</TD></TR></TABLE>
http://www.racerpartswholesale.com/naca.htm
Old Sep 25, 2004 | 02:34 PM
kb58's Avatar
Banned
Default Re: Where to get velocity stacks? (89civicdx)
I'm not so sure an airhorn is the best thing for brake ducts. The geometry is to let air be sucked in better, at the inlet of a TB or carb, not a brake duct. The duct should be placed in a high-pressure area, like right at the front of the car. Like the post above listed, just get the assemblies from RPW.
Old Sep 25, 2004 | 02:37 PM
KrautFed's Avatar
This is the Fab Forum.
Grease a hard mold (or I've also seen a large socket used)
Hydraulic press a pipe over mold.
After & Before
Old Sep 25, 2004 | 04:32 PM
tony1's Avatar
Geoff, i'm sure the stacks you use are the best way to do it, but what are the differences between yours and the full bell style that twm uses? Educate me.
Old Sep 25, 2004 | 04:46 PM
Default Re: Where to get velocity stacks? (tony1)
what is actually kind of interesting is that you get two options, both of which have diminishing returns/exponential decay behavior.
There are two compromises you need to make -- one is laminar flow (quality of the flow), the other is the mass flow rate. You can acheive a higher mass flow rate (the full lip is about 4% higher flow) with a poorer quality flow. By using this radius style we were able to get a high rate, but the flow is much more laminar, coupled with the runner shape which increases pressure with almost no increase in turbulence.
The lack of turbulence makes the flow extremely high pressure at the port inlet.
Of course, we do not yet know what will work, but this is what all of our research led us to believe.
I really wonder why TWM really doesnt use a conical shape in their runners?
edit: tony -- looks like someone's all motor mazda (assuming??) has the same runner shape, interesting coincidence!
http://www.twminduction.com/Th....html
Old Sep 25, 2004 | 05:00 PM
tony1's Avatar
That all makes sense. I've seen it done both ways and just didn't know which was better and why. Thanks.
Old Sep 25, 2004 | 05:06 PM
also, i was just thinking that on an ITB setup, it probably doesnt matter how turbulent the air is at the top of the horn, becuase it hits the butterfly anyway, so the more air the better, regardless of turbulence before the throttle plate. On a plenum/single TB setup, theres nothing to distrub flow in teh runner, and based purely on a generously sized plenum, the mass of flow should be there, and cleaning it up is key... i am a slacker and still have not gotten you those copies, i swear i will come thru soon!!!
Old Mar 31, 2005 | 02:57 PM
743power's Avatar
geoff, do you have these available now? If so, how much and what sizes. PM me please.
Old Apr 1, 2005 | 07:34 AM
99_GS-T's Avatar
Geoff, I would be interested in the same information. As far as sizing, I'm looking for overall length, runner outlet diameter, and maximum diameter of the bell mouth.
Thanks
Old Apr 5, 2005 | 04:27 PM
madhatter07's Avatar
Default Re: (99_GS-T)
hey guys, I'm looking for velocity stacks that go down to 1.5 inched OD and around 2 inches OD.
I though it was interesting how one of you guys made them, are there any cruxial measurements or angles or anything that would be important to consinder when making them?
Old Apr 5, 2005 | 05:55 PM
Bailhatch's Avatar
Default Re: Where to get velocity stacks? (KrautFed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrautFed &raquo;</TD></TR><TR><TD CLASS="quote">This is the Fab Forum.
After & Before
Nice, makes me wish I had a lathe. Pressed cold I assume?
HondaCivicSiR1
May 2, 2007 12:37 PM
98JDM_Type_R
Oct 19, 2006 07:57 PM
Nikos
Feb 26, 2005 05:04 PM
KOALA YUMMIES
Sep 10, 2004 02:02 PM
NWP4LIFE
Jul 3, 2004 10:29 AM
