stillrunning extremely RICH$$$$$$
Old Sep 23, 2004 | 09:40 AM
barry11j's Avatar
Default stillrunning extremely RICH$$$$$$
my 91 crx si..b16A swap is running 2 damn rich.....im gettinh like 8-10 mpg!!!!! it took me a whole damn tank of gas 2 travel 70-75 miles !! i go through plugs it least once a week.......i have 2.25 pipes from the man back...please help me pit..im about to purchase new injectors, and a fuel press reg....what else might be the problem...?~!!!!!!! thanx
Old Sep 23, 2004 | 09:49 AM
4drEF's Avatar
Keyboard Humorist
Default Re: stillrunning extremely RICH$$$$$$ (barry11j)
I suggest you figure out what the problem is before you start running out and buying parts.
Have you tested the fuel pressure to see what it is?
What ECU are you running?
Any CEL codes?
Old Sep 26, 2004 | 06:38 PM
barry11j's Avatar
Default Re: stillrunning extremely RICH$$$$$$ (4drEF)
i am running the obd0 ecu.....i checked the fuel pressure and it is where it needs 2 b
Old Sep 26, 2004 | 06:43 PM
89hbcivicguy's Avatar
check your IAT(intake air temp) sensor and then check your o2 sensor
Old Sep 26, 2004 | 06:45 PM
CRXBart's Avatar
I had a friend that had that same situation he had a vacumm leak somewhere and after he fixxed it. now it it's back to normal.
Old Sep 29, 2004 | 10:40 AM
barry11j's Avatar
Default Re: stillrunning extremely RICH$$$$$$ (CRXBart)
which v-lines do i look for..?
Old Sep 29, 2004 | 10:47 AM
munki3b0i's Avatar
My civic ran real rich, but I wasn't going thru spark plugs like you though. I converted my b16 over to obd1 it it solved all my problems.
Old Sep 29, 2004 | 11:07 AM
DOHC_EF's Avatar
Default Re: stillrunning extremely RICH$$$$$$ (munki3b0i)
Make sure you're getting spark to your spark plugs first. Than double check wiring.
Old Sep 29, 2004 | 12:31 PM
CRXBart's Avatar
check em all. remove unneccary ones.
Old Sep 29, 2004 | 01:57 PM
mymeatb18
do u have both o2 sensors hooked up and in the right order
Old Sep 29, 2004 | 07:30 PM
barry11j's Avatar
Default Re: stillrunning extremely RICH$$$$$$ (mymeatb18")
when i did the b16 swaP Everything(o2's) were hooked up right
Old Sep 29, 2004 | 08:23 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barry11j &raquo;</TD></TR><TR><TD CLASS="quote">when i did the b16 swaP Everything(o2's) were hooked up right
so you are running the 4-2-1 header and BOTH o2 sensors?
Old Sep 29, 2004 | 08:47 PM
SoftieB16's Avatar
I had the same exact problem with the same motor make sure ur Map sensor hoses are pluged in right that was my problem
DawgC2
Mar 10, 2012 12:11 PM
20_sec.hatch
Jul 27, 2011 02:50 PM
Cid156
Jun 7, 2010 01:12 PM
lmike6453
Nov 26, 2007 08:02 PM
cincispeedemon
Aug 6, 2005 08:56 AM
