Bad front or rear main seal?!?!?!
Old Sep 23, 2004 | 08:53 AM
fe519's Avatar
Default Bad front or rear main seal?!?!?!
Hey everyone. I just got a quick question. Theres a oil leak under my car but its really hard to tell where its coming from. I'm trying to pinpoint where the leak is but im hoping its just the oil pan gasket. Well, my question is what is the symptom of a bad front or rear main seal? Will it leak slowly? because i heard someone say that oil will be gushing out if its bad or something. Thanks for the help.
P.S. I got a 93 Prelude Si... and what is that thing, about an inch, under the oil filter? It has like a rubber boot over it and its directly under the oil filter?
Old Sep 23, 2004 | 09:04 AM
uncle's Avatar
Default Re: Bad front or rear main seal?!?!?! (fe519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fe519 &raquo;</TD></TR><TR><TD CLASS="quote">P.S. I got a 93 Prelude Si... and what is that thing, about an inch, under the oil filter? It has like a rubber boot over it and its directly under the oil filter?</TD></TR></TABLE>
Intermediate shaft?
Old Sep 23, 2004 | 09:13 AM
Behan's Avatar
the rate of the leak depends on the condition of the seal. The rear main could be slightly deteriorated and leak slowly or it could be FUBAR'ed and leak fast.
Where is leak coming from? You should figure that out, before trying to determine the seal thats bad.
good luck
Old Sep 23, 2004 | 04:12 PM
fe519's Avatar
Default Re: Bad front or rear main seal?!?!?! (Behan)
i dont really know where exactly is the leak coming from. the pan seems to be a little wet along with the tranny. It seems to be coming from the back of the pan/between the rear main seal. The problem is that it leaks so slow that its hard to pinpoint where it is coming from. I got like ~ 6 drops of oil under my car after 3 days... you guys think its the seal? how hard is it to change it anyways?
Old Sep 23, 2004 | 04:37 PM
@ries's Avatar
To change the rear main seal... you have to drop the trans. Not fun.
Old Sep 23, 2004 | 04:44 PM
Shakes's Avatar
space cadet
Default Re: Bad front or rear main seal?!?!?! (@ries)
could that be the oil pump?
edit: no clue where it is, but most likely on the timing belt side after i think about it.
slowpokesi
Apr 12, 2015 04:36 PM
v-tekxcitesME:D
Sep 9, 2009 03:01 PM
ekcivic9
Sep 14, 2005 11:48 AM
belkins
Feb 17, 2005 10:17 AM
I drive an IS300
Nov 14, 2004 01:30 PM
