How hard is it to swap brake pads on my R?
Old Dec 11, 2001 | 11:34 AM
Type-R 940's Avatar
New User
Default How hard is it to swap brake pads on my R?
Okay, here's the deal. Next year I will be running a full autocross schedule, and probably make the trip to the track at least 2x per month. So, what I've been looking for is a brake pad that will be good for autocross, yet stand up to anything on the track. From what I've heard, this is simply not possible, as anything less than a track pad is going to get destroyed under heavy track driving, and track pads need heat to work so they're no good for auto-x.
Soooo...I'm thinking about having two sets of pads, something like the Panther Plus for the track and some compromise pad for auto-x (R4S or 913 maybe?). How hard is it to change between different sets of brake pads? Would it be easier to just run the same pad in the rears all of the time and just swap the fronts (I've heard of people using race pads in the back all of the time)? Is this feasible, or is changing my pads all of the time just going to be too much of a pain in the ***?
Any advice would be much appreciated.
Old Dec 11, 2001 | 11:39 AM
Willard's Avatar
Default Re: How hard is it to swap brake pads on my R? (Type-R 940)
-jack the front up
-remove wheels
-use 14mm to remove the lower caliper bolt
-swing caliper up
-install new pads
-swing caliper back down (push piston back into caliper if needed)
-install 14mm
-install wheel
-test pedal
-drive
Will
tjtruong's Avatar
New User
Default Re: How hard is it to swap brake pads on my R? (Willard)
-jack the front up
-remove wheels
-swing caliper up
-install new pads
-install 14mm
-install wheel
-test pedal
-drive
Will
Right on!!! easy as that.
[Modified by tjtruong, 8:39 PM 12/11/2001]
Old Dec 11, 2001 | 11:43 AM
py1188's Avatar
Default Re: How hard is it to swap brake pads on my R? (tjtruong)
Very simple.
About a half hour worth of work. And thats if you're lazy like me
Old Dec 11, 2001 | 11:45 AM
Type-R 940's Avatar
New User
-jack the front up
-remove wheels
-swing caliper up
-install new pads
-install 14mm
-install wheel
-test pedal
-drive
Will
Does this work for the rear pads too? I heard it was more difficult to change the rear pads.
Old Dec 11, 2001 | 11:51 AM
Willard's Avatar
Rear
-jack car up
-remove wheels
-remove 2-10mm bolts holding shield on
-remove 2-14mm (or 12mm) bolts holding caliper on
-remove cotter-pin for the parking brake cable
-remove metal "C" clip that holds the parking brake cable
-remove caliper
-replace pads
-using a big screwdriver/needle nose pliers... twist the piston (clockwise) back into the caliper
-replace caliper
-install 2-14mm bolts
-install "C" clip and cotter-pin
-install the shield and the 2-10mm bolts
-replace wheel
-test pedal
-drive
Will
[sp]
[Modified by Willard, 3:52 PM 12/11/2001]
Old Dec 11, 2001 | 12:33 PM
yoshi234's Avatar
I shoot brides
hrm, the rears weren't that involved for me:
just like the fronts, except the piston cannot be pushed in. It has to be "screwed" in w/ a cube shaped t00l.
-y
Old Dec 11, 2001 | 12:39 PM
XR4racer's Avatar
You don't have to remove the C-clip or parking brake cable on the rear.. just remove the one 10mm bolt that holds the brake line tight, and then it will allow the caliper to come right off.
Old Dec 11, 2001 | 01:27 PM
nsxtcjr's Avatar
New User
Default Re: How hard is it to swap brake pads on my R? (XR4racer)
Suggestion so that you can find out exactly how hard it is: Try it.
Another suggestion: Do it with someone who's done it before so they can show you how. They don't need to have done it on the ITR; it's basically the same on all cars.
Old Dec 11, 2001 | 01:50 PM
Big Phat R's Avatar
You need to use copious amounts of anti-seize too.....
Old Dec 11, 2001 | 02:17 PM
BABY NSX's Avatar
Default Re: How hard is it to swap brake pads on my R? (Big Phat R)
Anti-seize or anti-squeel? I've never used anti-seize but go through a lot of anti-squeel. But with the HP+ pads nothing seemed to do the trick, they simply squeeled away..
Regards,
Old Dec 11, 2001 | 02:18 PM
CPR's Avatar
CPR
Default Re: How hard is it to swap brake pads on my R? (BABY NSX)
Regards,
I think the anti-seize are to make it easier to take the bolts off.
Old Dec 11, 2001 | 03:32 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
How hard would it be to change the rotors on an integra?
-jack the front up
-remove wheels
-swing caliper up
-install new pads
-install 14mm
-install wheel
-test pedal
-drive
Will
WhiteHonda
12
Jun 29, 2010 04:25 AM
97CWITR
16
May 15, 2009 09:35 PM
fso_BamBam
Jul 12, 2003 03:57 AM
Rain_man
Feb 1, 2003 02:51 PM
GRM Scott
16
Jan 29, 2002 05:15 PM
