Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Warping Rotors
Old Dec 11, 2001 | 11:15 AM
urbanlegend21's Avatar
New User
Default Warping Rotors
I believe my rotors are warped.......... they were brand new a little more than month ago
what are the different causes of warping? I know heat is the main cause but are there other ways? Is this a problem I should just get used to having with a track car?
Old Dec 11, 2001 | 11:16 AM
B18CXr's Avatar
Default Re: Warping Rotors (urbanlegend21)
proper cool down!!!!!!!!!!!!!!
proper torque of the lugs...
r2x's Avatar
r2x
Not quite an answer to your question but... brake ducting is your friend.
Old Dec 11, 2001 | 11:24 AM
New User
Default Re: Warping Rotors (r2x)
i know ducting always helps
I think this is where my problems lie, my lugnuts keep backing off, no matter what they are torqued to, and well not having a torque wrench I have put them on so tight I had to jump on the wrench to get them off
this may have caused my problem
Old Dec 11, 2001 | 11:30 AM
Gennady's Avatar
New User
I have the same problem. How can I alieviate it? Should I resurface my rotors?
Old Dec 11, 2001 | 11:31 AM
Chris's Avatar
i I had to jump on the wrench to get them off
Most likely. Also to eloborate on the proper cool down..
Do not park with e-brake, and roll car forward (or back) every couple minutes to expose the part of the caliper that was under the brake pads to promote even cooling.
Old Dec 11, 2001 | 11:36 AM
SJR's Avatar
SJR
I'd say that manually tightening your lug nuts is, like, a big no-no!!! Not sure that it's your only problem but it can't help. You should go and buy a _very_ cheap rod-type of torque wrench. They cost around $20 (or less) if memory serves, and they will not go out of calibration. That's the type of torque wrench that a lot people concerned about accuracy actually use. Sometimes, the most expensive tool is not always the best, eh? And actually, I believe the guy at Coletti told me that was what he uses whenever he needs to torque anything to some degree of accuracy.
That and ducting (my personal winter project) will hopefully greatly help. At my last outing on the jefferson, I warped my brand-spanking new front Brembos...
Old Dec 11, 2001 | 11:37 AM
New User
Default Re: Warping Rotors (Chris)
yeah I deifnently don't park with the e-brake on after a hard braking session, Rolling the car back in forth is a good suggestion
Old Dec 11, 2001 | 11:38 AM
Gennady's Avatar
New User
I have warping only on one rotor. The front left. My previous OEM rotor had that same problem. My rears are fine and the ebrake has done nothing to them. Should I resurface that rotor?
Old Dec 11, 2001 | 11:54 AM
Willard's Avatar
Default Re: Warping Rotors (Wont be beat)
Check your calipers... sounds like one is sticking.
Will
Old Dec 11, 2001 | 12:42 PM
CivicV10@18000rpm's Avatar
Default Re: Warping Rotors (B18CXr)
Proper warm up of the brakes are important too. "Rotors need to be gradually elevated to “race” temperatures before any severe use. A “nibble”, or slight vibration, normally indicates rotors that were heated too quickly. After initial “Seasoning”, when running your car at open track events or serious canyon carving, you should use the first lap of a session (or first couple miles of open road), to warm the brakes...." http://www.baer.com/bedding_street/
Old Dec 11, 2001 | 01:32 PM
Greyout's Avatar
Default Re: Warping Rotors (CivicV10@18000rpm)
how much torque is the right ammount? or is more important that they are all just even? (like if I use an air tool to tighten them)
Old Dec 11, 2001 | 01:37 PM
Crack Monkey's Avatar
Default Re: Warping Rotors (JDM LUDE)
85lb/ft is what I use. It varies by wheel type (alloy or steel), but only by about 5lb/ft, so I just do 85 all the time.
Old Dec 11, 2001 | 01:39 PM
B18CXr's Avatar
Default Re: Warping Rotors (Crack Monkey)
86 here.....warm up is also importante
Old Dec 11, 2001 | 01:50 PM
fast-R's Avatar
New User
Yeah, and make sure to use the cool-down lap to cool off your brakes. I usually try to not touch the brakes that last lap so that the moving air will help cool them before I stop in the pits.
4WDrift's Avatar
Morgan: i I had to jump on the wrench to get them off
this may have caused my problem.
Chris: Most likely. Also to eloborate on the proper cool down..
Jumping? Likely torque is over 150 lb-ft.
You shouldn't have to roll the car IF the cooldown lap was used properly, i.e. NO brakes. I've never seen anyone at BMWCCA or PCA schools need to do that.
Old Dec 11, 2001 | 04:17 PM
siisgood00's Avatar
New User
Default Re: Warping Rotors (4WDrift)
I have a 00 Si and TQ to 80. Good idea about rolling the car to expose the part of the rotor under the calpier,, never thought about that
Old Dec 11, 2001 | 05:30 PM
Chris's Avatar
Yea.. I do, but the wheel is still too hot to touch (i.e. BURNS!) so I feel its an extra precaution thats worth it.
Old Dec 11, 2001 | 06:27 PM
mojoGSR92's Avatar
So it sounds like Solo is the perfect place to warp rotors, or do you even get them to a high enough temperature for this to take place? I'm just concerned because my new brakes are sitting on the shelf, and I've never had good luck with rotors. Old ones are warped enough to make the steering wheel vibrate pretty violently.
Ways to properly maintain rotor cool down/heat up:
-No more E-brake after parking; just leave it in gear.
-Drive around after hard sessions of driving (may not be suitable in paddocks at Solo events).
Any further suggestions?
PS: 80 ft-lbs here. I use a cheap $40 Autozone special torque wrench. I'd be interested to see how good/bad the calibration is.
Old Dec 11, 2001 | 06:29 PM
MaddMatt's Avatar
I have cryo-treated rotors before. Although I'm a degreed Materials Scientist, I am at a loss as to why this works. They never mentioned cryogenics as a metal treatment at NC State so I know nothing about it. But for some reason it seems to work. I did this to my rotors on my Eclipse. That car would warp rotors on a trip to the grocery store. I got some Brembos cryo treated by Carbotech over 2 years ago. I even did a track school on them at CMP, a known abuser of brake systems. They are as straight now as the day I put them on.
Old Dec 11, 2001 | 06:53 PM
Honda318dx's Avatar
Default Re: Warping Rotors (MaddMatt)
Maybe that is something I should look into, I go threw rotors like a bitch.. I have the same brakes as an ITR, but 200lbs more weight and try to stop faster than them
Old Dec 11, 2001 | 07:11 PM
mojoGSR92's Avatar
I took a tour of race shop in Indy that does cryo treating. The guy giving the tour said something to the effect of, whenever the rotor has stress worked into it (maching or turning), it needs to be cryo treated. From the factory they have stress from the machining process. What this has to do directly with heat transfer is a little beyond my scope.
Is cryo treating really worth the money?
Anyone have any first hand experience with its advantages? (I have yet to hear of any disadvantages.)
Old Dec 11, 2001 | 07:26 PM
uncleben's Avatar
Few questions on warping...
1) I noticed just recently that when braking it has that feeling of warped rotors, you know where it kinda chug-chugs as you brake hard to a stop. (or is this a symptom of something else?)
2) If this is what's happening, is it obvious to the eye if it's getting warped? Can I tell by just eye-balling it?
3) I've heard that OE Brembo rotors are the best bang for the buck when replacing to be used with stock pads and calipers. Where can I order some from if I end up needing them?
thx!
Old Dec 11, 2001 | 07:35 PM
mojoGSR92's Avatar
Default Re: Warping Rotors (uncleben)
Order the rotors here. Great service, and everyone here will also recommend them. Great prices too. Mine came the next day, and only cost around $135. http://www.collettimotorsports.com/
Old Dec 11, 2001 | 07:37 PM
uncleben's Avatar
Default Re: Warping Rotors (mojoGSR92)
thanks,
any pointers on my questions?
