does anyone have free time to weld in socal for free :) ?
[pix courtesy of sandmracing.com] Im planning on sanding the ports down like so on my jdm 4-1 header
since they look like this right now
im looking to weld the outer part of the header like so, for reinforcement after I sand the ports down
http://redirect1.vip.store.yah...vie&r=
Modified by sim shadeee at 12:07 PM 2/3/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FawkJoo »</TD></TR><TR><TD CLASS="quote">Most welding shops only charge like 25-30 an hour for simple stuff, and the stuff you need will prolly only take like 5 minutes if that.</TD></TR></TABLE>
depending on the sort of welding he want, ,that might take up to an hour... Tig welding is pretty damn slow you know.
Kranked.
Kranked.
im in placentia i dont think this would be a problem! pm me or call the number in my sig and i will see how i can assist you.
i think for a welder to charge only 25-30 dollars and hour is a little under rated unless he operated out of his home... a professional heliarch "tig" weder will charge a shop rate of 60 to 80 dollars and hour... and most of the time its not just for the welding work but to actually preping the work ... and welding it.. I can honestly say something like this will take about 30-40 mins to do and should cost you around $40-50 dollars..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTRFAB »</TD></TR><TR><TD CLASS="quote">
i think for a welder to charge only 25-30 dollars and hour is a little under rated unless he operated out of his home... a professional heliarch "tig" weder will charge a shop rate of 60 to 80 dollars and hour... and most of the time its not just for the welding work but to actually preping the work ... and welding it.. I can honestly say something like this will take about 30-40 mins to do and should cost you around $40-50 dollars..</TD></TR></TABLE>
yep. for a cracked runner i was quoted "probably more than the cost of your header new". then i went to billy bob down the street and iirc it was like 65/hr. probably have better luck with a muffler shop than a fabricator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poopsicle »</TD></TR><TR><TD CLASS="quote">get a mugen already Ported! whoot whoot thought your dumhasses knew</TD></TR></TABLE>
Where do these people come from!?
FullRaceHonda
22
Apr 20, 2007 07:19 PM
onyx00
May 15, 2002 09:15 PM
