Wheres the A/C Filter on a 98 accord
Old Sep 22, 2004 | 10:57 PM
turbo83lude's Avatar
Default Wheres the A/C Filter on a 98 accord
Does anybody know where the A/C filter is located? Is in contained in the blower box under the dash or is it under the cowl near the windshield wipers?
thanks
Old Sep 23, 2004 | 04:55 AM
green98acc's Avatar
Default Re: Wheres the A/C Filter on a 98 accord (turbo83lude)
98-02 Accord's A/C Filters are located behind the glove box. You have to remove the glove box to gain access to them. Make sure you install them properly too... makes a big difference... they have flow markings on the filters, take note of the way they line up
Old Sep 23, 2004 | 08:14 AM
newdad's Avatar
Default Re: Wheres the A/C Filter on a 98 accord (green98acc)
yeah like he said they are behind the glove boy really simple to replace the arrows go faing towards the drivers side of the vehicle that is the way the ir flows....good luck ...spray some kind of freshner in ther so your car smell good when ac on..
Old Sep 23, 2004 | 02:55 PM
thanks guys.....off to change the filter so i can have some clean air......
Old Sep 24, 2004 | 06:55 AM
Heat's Avatar
It's not hard to get to, but it is a pain, took me maybe 25 minutes to get to it and put everything back.
Just remember to disconnect your battery before unplugging the airbag (which you'll have to do to get to the filter).
If you have a Haynes manual, it will give you pretty good information on getting to it.
Old Sep 24, 2004 | 08:46 AM
notoriousB's Avatar
Default Re: Wheres the A/C Filter on a 98 accord (Heat)
I didn't have to unplug any airbags when doing the cabin filters in my 98 accord.
take out the glove box, remove filters, reinstall. It's not terribly difficult, a little tight, but pretty easy. a helms manual's instructions make it so easy...
transpar_nt
Jul 3, 2005 05:36 AM
boiwitwhitehond
Sep 28, 2004 12:34 PM
budjenning
May 2, 2004 08:17 PM
SIMATIC
Aug 18, 2003 01:35 PM
briq4
Sep 21, 2001 07:50 PM
