Accord rear camber
Hello I have a 95 accord 4dr and the rear tires have nasty feathering on the inside. I have eibach pro kit with stock struts. If you stand from the back of the car you can tell there is negative camber. The question I have is how much is there? I see decent kits for up to -1.75 degrees. Is this enough? Also, there's a squeak from the back suspension when i sit in the car or push on the back, is that my old struts or my springs? Or something else? Any help would be appreciated. Thanks
Michael
Michael
if your tires are feathering, that's generally a sign of a toe problem. camber will just cause the insides to wear faster.
i would assume that the camber kits you mentioned have enough to correct your camber issue, but the best way to tell is have a shop check your alignment.
squeak wise, it could be your shocks, but it could also be your springs rubbing against the top mount if the rubber "pad" from the original springs wasn't put onto the new ones.
02 accord
Jan 31, 2010 07:06 PM
hondaracin24
Aug 27, 2004 08:28 AM
