door won't open.
Old Sep 22, 2004 | 08:55 PM
alb_accord's Avatar
Default door won't open.
what's up guys. i have a 90 accord ex automatic.
today when i closed the door everything worked fine. but wheni tryed to open it again the door won't open. the power locks and the key work fine but the door won't open. its the drivers door.
do u guys know a way on how to open the door and how to fix the lock???
Old Sep 23, 2004 | 06:36 AM
Mike813's Avatar
Default Re: door won't open. (alb_accord)
did you try opening the interior doorhandle, see if the latch popped out or somethingits held on by a piece of colored plastic.
Old Sep 23, 2004 | 06:43 AM
Heat's Avatar
Default Re: door won't open. (Mike813)
Hmm... with the door closed can you take off the inside trim? I guess you'd have to figure out a way to do it, something must have slipped on the inside. I'm assuming you've tried both the inside and outside door handle?
Else, have you ever watched The Dukes of Hazzard? You could just use the window... (joking)
Old Sep 23, 2004 | 06:46 AM
alb_accord's Avatar
lol. yeah i tryed both sides. both door handles won't open the car. power locks and the key lock work.
even if i took the cover off i still don't know what to look for
Old Sep 23, 2004 | 06:56 AM
Mike813's Avatar
Default Re: (alb_accord)
if you open up the interior door handle,,, youll see thin metal bars... they should be hooked on to the back of the doorhandle by a plastic clip (usually colored) that holds it steady.
Old Sep 23, 2004 | 07:18 AM
Heat's Avatar
Default Re: (Mike813)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 &raquo;</TD></TR><TR><TD CLASS="quote">if you open up the interior door handle,,, youll see thin metal bars... they should be hooked on to the back of the doorhandle by a plastic clip (usually colored) that holds it steady.</TD></TR></TABLE>Yeah, once you open it up you'll see what the door handle does (pulls a metal rod which opens the door).
Take a look at that rod, pull on int, take a look at what it connects to, pull on that, etc. The inside of a door isn't complicated.
Old Sep 23, 2004 | 10:50 AM
ZexyAccord's Avatar
Default Re: (Heat)
The car doesnt like you.... It tried to keep you away from driving it... lol
its a sign
Old Sep 23, 2004 | 01:53 PM
alb_accord's Avatar
i open the cover. took a look of it. everything seems to work fine but the door still won't open. wtf is wrong with ****.
Old Sep 23, 2004 | 02:46 PM
91EXRMANUAL
Guest
Posts: n/a
Maby the fact that you have no hands?
Old Sep 23, 2004 | 04:57 PM
Mike813's Avatar
Default Re: (91EXRMANUAL)
i really dont know what to tell you,,,
power door locks work?
keys turn it open/close?
door handles your not too sure about right?
both doors are stuck the same way??
if your not sure about how the door lock looks, try going to http://www.hondaautomotiveparts.com/ they give a black/white diagram of what you are looking at...
Old Sep 23, 2004 | 06:38 PM
alb_accord's Avatar
its only one door.
the power locks work fine.
the thin things that are attached at the door handles work fine. i took a look at the other door to see how it works and both door locks work the same. but the drivers door won't open.
i am hating my car so much right now.
Old Sep 23, 2004 | 09:06 PM
Chiovnidca's Avatar
Sounds like your latch is f-ed up. Someone had a how-to posted a while back on drilling the latch to get the door open.
Old Sep 26, 2004 | 06:13 AM
accord91lx's Avatar
Default Re: (Chiovnidca)
as posted on cb7tuner... a search would reveal my link....
http://www2.fwi.com/~djmccoy/door.pdf
m.glisson003
Aug 7, 2011 12:36 PM
todd bayliss
Jul 31, 2009 04:54 AM
erck
Jul 27, 2006 06:25 PM
BB4
Aug 18, 2005 03:39 PM
avrfan
Jun 23, 2002 09:32 PM
