what is this sensor on the right of my intake manifold??
Old Sep 22, 2004 | 07:29 PM
tuan...'s Avatar
Default what is this sensor on the right of my intake manifold??
i had a connector that i cant seem to find a place to put it. it splits off from the same harness as the IAT sensor. the motor is a 97 h22a4 sh. it is the green connector in the pic below. also my evap purge solenoid looks funny.. i think the cap on top might of fallen off. can i just plug the top with a vacuum cap?
Old Sep 22, 2004 | 07:49 PM
SUB-0 H23's Avatar
Default Re: what is this sensor on the right of my intake manifold?? (v0gueSilver_Dc2)
AIR TEMP. SENSOR
*EDIT: whoops did not read whole thread
Old Sep 23, 2004 | 04:26 AM
tuan...'s Avatar
helpppppp
Old Sep 23, 2004 | 04:31 AM
pentaq's Avatar
Default Re: (v0gueSilver_Dc2)
Power steering pressure sensor? Seems so...
Old Sep 23, 2004 | 05:10 AM
Greyout's Avatar
Default Re: (pentaq)
my guess is that its the harness that plugs into the secondary butterfly valve control box under the manifold.
Old Sep 23, 2004 | 07:38 AM
tuan...'s Avatar
the harness for the butterfly sensor is already plugged in, i think it may be the power steering pressure sensor, where does it go?
Old Sep 23, 2004 | 10:06 AM
Quade's Avatar
Below the intake manifold you will see a metal line with a sensor installed in it. It belongs there.
Old Sep 23, 2004 | 11:05 AM
Adam.'s Avatar
Default Re: (Quade)
Green = Power Steering.
Old Sep 23, 2004 | 11:08 AM
99_SH's Avatar
Default Re: (DarkKnight[DMD])
Its always good too label your connectors when doing a swap. I stumpled on the PSP switch also back in the days...
Old Sep 23, 2004 | 11:29 AM
PrecisionH23a's Avatar
Drop the plug down, jack your car up, get underneath it and look for a line with rubber coverings on it. It will have a green plug where that sensor goes in.
Old Sep 23, 2004 | 11:48 AM
tuan...'s Avatar
well if its psp, then theres really no point in hookin it up, i took my p/w off
crist488
11
Jul 15, 2011 09:26 PM
lude22vti
Jul 10, 2007 04:12 AM
str8JDMteggy
Oct 23, 2006 12:57 PM
Punker1234
May 30, 2005 04:59 PM
