Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
AC Issue Help Please!
Old Jun 7, 2026 | 05:37 AM
Falcon1925286's Avatar
Default AC Issue Help Please!
For the Honda master minds on a 2014 Accord. When I crank the car, the AC air blows warm on full Lo, almost like ambient temp circulating. Once I start driving for about 10 to 15 minutes, it starts to chill decently, but not great, at least it's bearable. I put some manifold gauges on it and got 30 on the low side and about 275 on the high side. Let the car run for about 30 minutes, fully cold, with the doors open, and the low went to 35 and the high to about 325. Keep in mind I had no airflow on the condesnor, and it was in the driveway in direct sun. Checked the blend motor visually on the driver's side by running the AC back and forth from low to high, and the motor moves from extreme to the other. I'm not a Honda guy, and everything online appears to point to a possible stuck or clogged expansion valve or evaporator coil. I really don't want to go down a rabbit hole of trying to replace or access those components if there is something else I can do to 100% verify. I've had the car for about 6 years, and the AC has always worked great, and no maintenance on the system has been performed since I've owned it. Any help or insight would be GREATLY appreciated here.
Northerner28
Oct 5, 2018 07:12 PM
jties
Honda CR-V & Element
Sep 1, 2016 12:31 PM
nasteawhun
Jun 22, 2008 06:29 PM
you2envious
Apr 27, 2002 07:42 PM
