CEL 41 but not 41 NEED HELP!
Old May 21, 2026 | 05:13 PM
Rynoryt's Avatar
Default CEL 41 but not 41 NEED HELP!
I have a Honda Prelude 1994 with a Honda P14 ECU and I’m going crazy trying to solve a persistent Code 41 (O2 Heater) issue.The car actually runs perfectly fine: smooth idle, drives normally, no noticeable misfires, fuel consumption seems normalBUT:the check engine light stays on constantly only Code 41 is storedWhat I’ve already done: swapped the ECU with another P14 replaced the O2 sensor tested the O2 heater resistance → about 16 ohms. followed the entire Chilton troubleshooting procedure still inconclusive
Now comes the weird part:If I COMPLETELY unplug the O2 sensor connector:the error remains EXACTLY the sameonly Code 41NO Code 1From what I know about Honda OBD1 systems, I would expect:Code 1 for missing O2 signalor Code 1 + 41 togetherBut it keeps showing ONLY Code 41.Another very strange thing: Using hondash the O2 reading stays fixed around ~3.8V, even though a narrowband sensor should fluctuate roughly between 0V and 1V.NOW HERE IS THE REALLY CRAZY PART: If I place a multimeter probe directly across the O2 sensor A+B pins:I get around ~0.43V to 0.45Vand AT THE SAME TIME HondaDash suddenly “corrects itself” and starts showing a realistic voltage tooSo somehow: the multimeter itself seems to change the circuit behavior.That makes absolutely no sense to me.At this point I’m starting to suspect:wiring harness leakagebad groundingweird ECU pull-up behavioror an issue in the O2 signal line itselfQuestions:Has anyone ever seen a Honda OBD1 system keep ONLY Code 41 even with the O2 sensor completely unplugged?Does the constant ~3.8V point more toward a short/leak in the harness?Could the multimeter “fixing” the reading indicate a grounding or impedance problem?Is it worth rewiring the ENTIRE ECU → O2 sensor harness from scratch?Pinout:A6 = heater ground control (Orange/White)Green/WhiteWhiteBlack/YellowCan the Black/Yellow wire safely be temporarily connected to a reliable switched 12V source for testing?Any deeper technical insight would be greatly appreciated because this failure behaves completely outside the normal Honda OBD1 patterns I’m familiar with.
iLOVEmyEMone
Dec 29, 2005 02:57 PM
Eucalyptus lude
Jun 3, 2005 01:42 PM
messeduprex
Apr 11, 2005 08:08 AM
wizzards581
Mar 22, 2004 07:31 PM
turboxsi
Oct 27, 2003 04:33 AM
