Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Help with AC -- blend doors?
Old May 14, 2026 | 02:29 PM
COLIN86325's Avatar
5 Year Member
Default Help with AC -- blend doors?
Hi folks,
I have a 2014 Accord LX and the air conditioning on the 2 left (driver side left, and left center) vents is not as cold as the 2 vents on the right side.
i scanned for codes but everything checked out ok. I then ran the "input display mode" self-diagnostics and noted:
  • 6 (driver side air mix opening - lower value is for cool, higher value for warm) -- 0% opened
  • 7 (passenger side air mix opening - lower value is for cool, higher value for warm) -- 16% opened
  • 8 (recirculation control opening) - - 58% with recirculate button engaged, 100% with recirculate disabled
Temp control was set for full cold in all above tests.
Can anyone advise what i should look at?
For #8, I had assumed that recirculate engaged would cause it to drop to 0% open. Is 58% an expected value?
For #7, i expected that recirculate would set the passenger side to 0% opened, like it is on the driver's side.
Thanks in advance for any help.
Cheers,
Colin​​​​​​​
wallow
14
May 31, 2020 01:50 PM
emsman1
Feb 19, 2014 12:03 PM
jacksonww
Jul 16, 2008 01:16 PM
nickwilmot
Jul 28, 2005 06:29 PM
00b18b
Dec 14, 2001 01:55 PM
