Compression ratio limit for stock B18B rods
Old May 11, 2026 | 10:33 PM
acr_8133's Avatar
Default Compression ratio limit for stock B18B rods
Hi, I will be buying aftermarket high compression pistons for my LSVTEC and they say it will make around 12.1:1 CR with my head-block combo. I'm wondering if the stock B18B rods will be able to handle that high. This is a daily so I won't have it tuned to the limit.
Old May 12, 2026 | 03:33 AM
theYBLEGAL's Avatar
Loved
Default Re: Compression ratio limit for stock B18B rods
99% of aftermarket pistons use a floating wrist pin. OEM rods/pistons use a press-fit pin. Did you buy pistons compatible with press fit rods?
Old May 12, 2026 | 12:09 PM
acr_8133's Avatar
Haven't bought it yet but the listing says they're press-fit.
Edit: It's a rep CTR piston from YCP.
Old May 12, 2026 | 03:16 PM
theYBLEGAL's Avatar
Loved
Oh. Ah.
Yeah they will handle that just fine. Stock rods can handle a lot more torque than a B18 can make naturally aspirated.
Old May 12, 2026 | 08:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I would not suggest you getting the CTR style dome top piston design... the combination you have posted will have a compression ratio of at least 13.7:1 !!! For a pump gas street car, I would recommend using a PR3/P30 style/contour piston. That will put your compression ratio at about 12.1:1... where you need to be.
boostedbatch
Oct 3, 2010 01:30 PM
berts95ej
Sep 17, 2007 08:54 PM
wushubrian
25
Aug 31, 2006 01:52 PM
psegs80
Oct 9, 2005 10:35 AM
hybrid_vtec
Aug 3, 2004 04:30 PM
