🆙 Upgrade to the Wolfbox G900Pro: 4K Sony IMX678 Sensor & Seamless OEM Look
Old May 6, 2026 | 07:28 PM
Wolfbox's Avatar
H-T Premium Sponsor
Icon6 🆙 Upgrade to the Wolfbox G900Pro: 4K Sony IMX678 Sensor & Seamless OEM Look
At Wolfbox, we are committed to providing the highest resolution possible alongside a clean, integrated installation. This pursuit of crystal-clear imaging and a "factory-installed" look is exactly what guided the development of theWolfbox G900Pro.
Eliminate Blind Spots: Dual-channel with 4K Front + 2.5K Waterproof Rear camera
It's a dual-channel setup with 4K in the front and a 2.5K waterproof camera in the back. The main goal is to give you a crisp, live feed of what's behind you while you're cruising.
We went with the Sony IMX678 sensor because it handles different lighting conditions really well. Whether it's regular daytime driving, low light, or even tricky backlight, the image stays clear enough to easily read plates and see road details.
Seamless OEM Look
For those who prefer a sleeker, more integrated look, the OEM bracket is the way to go. This option requires purchasing the Wolfbox OEM bracket separately. You'll need to remove your car's original rearview mirror and its supporting bracket, then replace it with the Wolfbox mount. While it's slightly more time-consuming to set up, the end result is worth the effort. the dash cam will look like it was part of your car's original design!
Note: There are two other ways to install the dashcam; for more info, please check this thread:https://honda-tech.com/forums/miscel...m_content=post
Ultimately, the Wolfbox G900Pro is designed to deliver the highest definition recording with a clean, professional look that blends perfectly with your vehicle.
Product link: https://wolfbox.com/products/wolfbox...vis-678-sensor
Wolfbox enhances the driving experience with vibrant and reliable automotive electronics.
Dare to EverywhereFacebookInstagramYouTube
Customer Service: service@wolfbox.com
Old May 6, 2026 | 07:40 PM
Wolfbox's Avatar
H-T Premium Sponsor
Default Re: 🆙 Upgrade to the Wolfbox G900Pro: 4K Sony IMX678 Sensor & Seamless OEM Look
Other Key Features of the G900Pro
12 inch Touch Screen
The large display makes it easy to toggle between the front and rear cameras. You can also use the split screen mode if you want a full view of your surroundings at a single glance.
High Speed Wi-Fi and App Sync
We upgraded this to 5.8GHz Wi-Fi, which is a massive jump from the standard 2.4GHz versions. It pushes download speeds up to 8MB/s, so you can pull footage to your phone for insurance or sharing without sitting around waiting for a progress bar.
Voice Control
You can keep your hands on the wheel and manage all the basic functions with simple voice commands. It is a small detail that makes a big difference when you need to stay focused on the road.
Old May 6, 2026 | 07:44 PM
Wolfbox's Avatar
H-T Premium Sponsor
24 Hour Parking Monitoring
This mode watches over your rig while you are away. It automatically records any incidents, giving you peace of mind while parked up for the night.
Reversing assistance
When you're ready to park up at a pitch, it pulls up simple guidance lines to make backing into tight spots a whole lot easier.
Clikc the product link to learn more: https://wolfbox.com/products/wolfbox...vis-678-sensor
