1999 Honda accord 2.3 lx coupe f23a1 swap with f23a
Old Apr 28, 2026 | 11:49 AM
ErikG's Avatar
Default 1999 Honda accord 2.3 lx coupe f23a1 swap with f23a
I’m going to be doing a f23a jdm swap on my accord and I want any info on the swap I’ve been seeing maybe things but I want some information on what needs to be swapped and if I can run my stock ecu with the f23a
Old Apr 28, 2026 | 04:54 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1999 Honda accord 2.3 lx coupe f23a1 swap with f23a
Exhaust manifold will be fine, leave it on the JDM. Usually the intake and distributor are just different enough.
Reuse your intake, VTEC solenoid/sensor, intake, and water tube from your USDM engine for an easy swap.
Adjust the valves and check the plugs.
Old Apr 30, 2026 | 11:06 AM
ErikG's Avatar
I seen something about the temp sensors being wired differently like one to the ecu and one to the dash and something about the crank sensor
Old May 2, 2026 | 12:32 PM
MAD_MIKE's Avatar
MM Gruppe B
There are two things to look for.
JDM vs USDM differnces, which can mostly be avoided by retaining your USDM intake/distributor/watertube/etc. and 98/99 vs 00-02 differences.
98/99 cars use two thermo sensors. One for the ecu and another for the gauge.
On the later cars there is only one thermo sensor for the ECU which then sends info to the dash.
Swap USDM original sensors onto your JDM engine.
Old May 4, 2026 | 10:02 PM
ErikG's Avatar
So as long as I swap all the accessories and sensors it should run good
Old May 7, 2026 | 03:27 AM
ErikG's Avatar
also I seen if I run my usdm power steering pump alternator and ac compressor I have to use my usdm crank pulley and change belt sizes
Wes072
Oct 22, 2022 01:55 AM
aldo.moreno80
Mar 8, 2016 04:22 AM
Sparky97accord
Feb 22, 2014 10:00 AM
azn_88
May 31, 2007 01:40 PM
