Honda Civic (2016 - Current) 10th Generation Civic Forum Civic / Si / Type-R Discussions
Sponsored by: CARiD
K20Z3, Crank pully/harmonic balancer
Old Apr 22, 2026 | 06:55 AM
cbstd's Avatar
Icon4 K20Z3, Crank pully/harmonic balancer
After 215,000 miles, the crank pulley/harmonic balancer **** the bed. Symptoms: A very clear noise of a failing belt/bearing was present in the engine compartment, particularly at cold start. The A/C stopped working.
Crank pulleys and harmonic balancers are typically "iron clad" dependable and not typically something that you would commonly call a "wear issue." But Honda choose to make the late model items with a hard rubber core to reduce NVH.
In time, nearly 20 years of daily use, that rubber core has retired and needed to be replaced. Once replaced, the A/C compressor now has a better grip on the accessory drive belt and creates cold air again.
I mention all of this only because this was a "new to me" situation and I thought I would share with the community.
Old Apr 22, 2026 | 07:06 AM
speedooo's Avatar
Default Re: K20Z3, Crank pully/harmonic balancer
Pretty common. I replaced mine at 120k.
My AC compressor also seized around 200k.
hotdoggies
13
May 16, 2020 02:28 PM
black0hatch
Honda CR-V & Element
Sep 24, 2012 09:12 AM
burgboy73
Nov 17, 2006 02:01 PM
Pher
Mar 21, 2006 07:46 PM
